245
I'm trying to mount an hfsplus filesystem in a Xubuntu 12.04 VM (kernel version 3.2.0-23-generic) but when I type mount -o remount,rw /dev/sdb3 in command line it returns not mounted or bad option. Any help would be appreciated.
mook765
  • 18,644
Alkthree
  • 2,777
6 Answers6
344
The correct syntax is:
sudo mount -o remount,rw /partition/identifier /mount/point
Where mount/point is /partition/identifier's corresponding mountpoint, as listed by the following command:
mount -v | grep "^/" | awk '{print "\nPartition identifier: " $1  "\n Mountpoint: "  $3}'
For example, say that the above command gives this:
Partition identifier: /dev/sda1
 Mountpoint: /
Partition identifier: /dev/sda2
 Mountpoint: /boot
Partition identifier: /dev/sda3
 Mountpoint: /test
The following would be the correct syntax. (We start by unmounting it, if it's already mounted.)
sudo umount /test
sudo umount /dev/sdb3
sudo mount -t hfsplus -o rw,remount -force /dev/sdb3 /media/untitled
Richard
  • 8,588
SirCharlo
  • 40,096
62
for busybox/android users:
Oddly, I needed to add a space (in contrast to normal usage) between 'remount' and 'rw':
mount -o remount, rw /
otherwise it wouldn't work.
UPDATE: it seems that this is almost never the case (see comments). Not sure which busybox-version + android-version I was running. I'll just leave this here in case anyone still runs into it.
10
Running dmesg | grep hfs showed that the filesystem was unmounted incorrectly, which I was able to repair using
fsck.hfsplus /dev/sdb3/
Alkthree
  • 2,777
First, let us fix NTFS problems (if you have an Ubuntu/Windows dual boot setup)
sudo ntfsfix /dev/sda7
Before mounting we need a Directory (folder)
mkdir ~/Desktop/disk
Now mount the partition
sudo mount /dev/sda7 ~Desktop/disk
In this case "sda7" is the partition name. Now you read from and write to the partition.
Tooniis
  • 1,602
mmblack
  • 41
I have Dragonboard 410c I connecting via adb I wanted to mount the physical sdcard as RW. the following worked for me.
adb root
adb shell
su
mount -o remount,rw /storage/sdcard1   /storage/sdcard1
So I can now access it in rw mode as /storage/sdcard1
nb. /storage/sdcard0 is emulated and is /sdcard
First I typed mount to see the results and determine the mapping I wanted altered to full access was /media/linux/OLD_PC.
This worked fine to unlock the files and folders within my old Windows system partition.
sudo mount -o remount,rw /media/linux/OLD_PC  /media/linux/OLD_PC
Kulfy
  • 18,154
Noah
