I have an bootable flash-card (with acronis (not my installation)), I may read but cannot copy file into it. When I uses windows, then I not have any problem, but I cannot use this card in ubuntu - have error Read-only file system
~ $sudo cp -f vbinst.sh /media/valeriy/TERMINAL/
[sudo] password for valeriy:
cp: cannot create regular file '/media/valeriy/TERMINAL/vbinst.sh': Read-only file system
$ sudo fdisk -l
Disk /dev/sda: 931,5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical):
512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096
bytes Disklabel type: gpt Disk identifier:
9F6D513D-4906-4670-9DF3-57280CEF2E8B
Device         Start       End   Sectors  Size Type
/dev/sda1       2048   3905535   3903488  1,9G Linux swap
/dev/sda2    3905536 199217151 195311616 93,1G Linux filesystem
/dev/sda3  199217152 394528767 195311616 93,1G Linux filesystem
Disk /dev/sdb: 119,2 GiB, 128035676160 bytes, 250069680 sectors Units:
sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512
bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes
278B77A6-1ACA-45F8-8C6A-13727B72BA6F
/dev/sdb1       2048    739327    737280   360M  EFI System
/dev/sdb2     739328   1001471    262144   128M  Microsoft reserved
/dev/sdb3    1001472 246554623 245553152 117,1G  Microsoft basic data
/dev/sdb4  246554624 250058751   3504128   1,7G  Windows recovery environment
**Disk /dev/sdc: 14,6 GiB,** 15676211200 bytes, 30617600 sectors Units:
bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos Disk identifier: 0x018ae7e6
Device     Boot    Start      End  Sectors  Size Id Type
/dev/sdc1             63 30617599 30617537 14,6G  c W95 FAT32 (LBA)
$ mount
- sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
- proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
- udev on /dev type devtmpfs (rw,nosuid,relatime,size=4007548k,nr_inodes=1001887,mode=755)
- devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
- tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=806368k,mode=755)
- /dev/sda3 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
- securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
- tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
- tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
- tmpfs on /sys/fs/cgroup type tmpfs (rw,mode=755)
- cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
- pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
- efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
- cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb,release_agent=/run/cgmanager/agents/cgm-release-agent.hugetlb)
- cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
- cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
- cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
- cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,clone_children)
- cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
- cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
- cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids,release_agent=/run/cgmanager/agents/cgm-release-agent.pids)
- cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event,release_agent=/run/cgmanager/agents/cgm-release-agent.perf_event)
- cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
- systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16717) mqueue on /dev/mqueue type mqueue (rw,relatime)
- debugfs on /sys/kernel/debug type debugfs (rw,relatime) fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
- hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
- /var/lib/snapd/snaps/heroku_3534.snap on /snap/heroku/3534 type squashfs (ro,nodev,relatime)
- /var/lib/snapd/snaps/heroku_3560.snap on /snap/heroku/3560 type squashfs (ro,nodev,relatime)
- /var/lib/snapd/snaps/core_5145.snap on /snap/core/5145 type squashfs (ro,nodev,relatime)
- /var/lib/snapd/snaps/heroku_3538.snap on /snap/heroku/3538 type squashfs (ro,nodev,relatime)
- /var/lib/snapd/snaps/core_5328.snap on /snap/core/5328 type squashfs (ro,nodev,relatime)
- /dev/sdb1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
- /dev/sda2 on /home type ext4 (rw,relatime,data=ordered)
- binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
- cgmfs on /run/cgmanager/fs type tmpfs (rw,relatime,size=100k,mode=755) tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=806368k,mode=700,uid=1000,gid=1000)
- gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
- gvfsd-fuse on /home/valeriy/.gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
- /dev/sdc1 on /media/valeriy/TERMINAL type vfat (ro,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
How to resolve this task but not crack flash-card?
sudodus
  • 47,684
The partition on the card is mounted read-only ro:
You can unmount it and mount it again, this time with read-write rw permissions. The following link answering another AskUbuntu question may help with details.
Mount NTFS partition in a USB drive with custom permissions and owner
sudodus
  • 47,684
