With sudo lshw -C disk I get
*-cdrom
description: DVD-RAM writer
product: DVDRAM GU71N
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: 1.01
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=ready
*-medium
physical id: 0
And with sudo mount /dev/sr0 /dev/dvd I get:
mount: /dev/sr0 is write-protected, mounting read-only
mount: wrong fs type, bad option, bad superblock on /dev/sr0,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
And when I once hit the Esc key during startup - with the DVD in the tray - one of the boot messages read:
I/O buffer error in /dev/sr0 at sector 4096
Does anybody know what the problem is?
Update 1: I have done the stuff suggested in How to install all existing media codecs? - only two additional packages were needed. So my computer was already up to date in this regard.
But I now attempted sudo mount /dev/sr0 /dev/dvd again, followed by dmesg:
[ 519.520092] sr 1:0:0:0: [sr0] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 519.520102] sr 1:0:0:0: [sr0] Sense Key : Illegal Request [current]
[ 519.520109] sr 1:0:0:0: [sr0] Add. Sense: Read of scrambled sector without authentication
[ 519.520113] sr 1:0:0:0: [sr0] CDB:
[ 519.520116] Read(10): 28 00 00 00 04 00 00 00 02 00
[ 519.520131] blk_update_request: I/O error, dev sr0, sector 4096
[ 521.020285] sr 1:0:0:0: [sr0] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 521.020297] sr 1:0:0:0: [sr0] Sense Key : Illegal Request [current]
[ 521.020304] sr 1:0:0:0: [sr0] Add. Sense: Read of scrambled sector without authentication
[ 521.020308] sr 1:0:0:0: [sr0] CDB:
[ 521.020311] Read(10): 28 00 00 00 04 01 00 00 01 00
[ 521.020328] blk_update_request: I/O error, dev sr0, sector 4100
[ 521.020335] Buffer I/O error on dev sr0, logical block 1025, async page read
I think "scrambled sector" refers to the CSS encryption that exists on DVDs - do I still need to install something?
Update 2: Using VLC and its "Open Disc..." dialog, now it works. And this:
mount: mount point /dev/sr0 is not a directory
dmesg | tail
[ 1378.434161] UDF-fs: INFO Mounting volume 'PLATOON', timestamp 2000/09/24 06:26 (1000)
...but yet, the DVD doesn't appear anywhere. I can't navigate to the DVD.
