I've upgraded a virtual server (running on vmware) to 18.04 and now I get a lot of errors when I do sudo apt-get upgrade
Ubuntu 18.04.1 LTS (GNU/Linux 4.15.0-29-generic x86_64)
$ sudo apt-get upgrade
The following packages were automatically installed and are no longer required:
  linux-headers-4.15.0-24 linux-headers-4.15.0-24-generic linux-image-4.15.0-24-generic
  linux-modules-4.15.0-24-generic linux-modules-extra-4.15.0-24-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up irqbalance (1.3.0-0.1) ...
insserv: Script eventlogd is broken: incomplete LSB comment.
insserv: missing `Provides:' entry: please add.
insserv: missing `Required-Start:' entry: please add even if empty.
insserv: missing `Required-Stop:'  entry: please add even if empty.
insserv: missing `Default-Start:'  entry: please add even if empty.
insserv: missing `Default-Stop:'   entry: please add even if empty.
insserv: Script likewise is broken: incomplete LSB comment.
insserv: Script lwsmd is broken: incomplete LSB comment.
insserv: Script lsassd is broken: incomplete LSB comment.
insserv: Script lwregd is broken: incomplete LSB comment.
insserv: Script netlogond is broken: incomplete LSB comment.
insserv: Script dcerpcd is broken: incomplete LSB comment.
insserv: Script lwiod is broken: incomplete LSB comment.
initctl: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
insserv: warning: script 'irqbalance' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `irqbalance'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `irqbalance'
insserv: warning: script 'atd' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `atd'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `atd'
insserv: warning: script 'screen-cleanup' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `screen-cleanup'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `screen-cleanup'
insserv: warning: script 'apport' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `apport'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `apport'
insserv: warning: script 'nmbd' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `nmbd'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `nmbd'
insserv: script postgresql-8.3: service postgresql already provided!
insserv: script postgresql-8.3: service postgresql-8.3 already provided!
insserv: warning: script 'smbd' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `smbd'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `smbd'
update-rc.d: error: irqbalance Default-Start contains no runlevels, aborting.
dpkg: error processing package irqbalance (--configure):
 installed irqbalance package post-installation script subprocess returned error exit status 1
 irqbalance
How can I repair it?
Zanna
  • 72,312
sudo apt remove irqbalance
That command did remove the errors and I'm satisfied. Thanks everyone involved.
