I have reinstalled my system, a Samsung Series 9 laptop with a clickpad, under Ubuntu 12.04. I reinstalled it a few times and re-configured it with the same OS because I had issues with the filesystem getting corrupted (ext4 on this SSD with this kernel isn't so great apparently).
Anyway, I re-installed it for a Nth time and configured the ClickPad the same way as before:
/usr/share/X11/xorg.conf.d/52-clickpad.conf
Section "InputClass"
Identifier "np900x3b clickpad"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event*"
Option "ClickPad" "1"
Option "ClickFinger1" "1"
Option "ClickFinger2" "3"
Option "ClickFinger3" "2"
Option "FastTaps" "1"
Option "RightButtonAreaLeft" "2000"
Option "RightButtonAreaTop" "1500"
EndSection
I had the same configuration before (I actually copied it from a USB drive), and it worked fine. Yet I get this after restarting X:
$ synclient -l | grep -i "\(right\|click\|fast\)"
RightEdge = 2974
ClickTime = 100
FastTaps = 1
ClickFinger1 = 1
ClickFinger2 = 3
ClickFinger3 = 2
AreaRightEdge = 0
ClickPad = 1
RightButtonAreaLeft = 0
RightButtonAreaRight = 0
RightButtonAreaTop = 0
RightButtonAreaBottom = 0
MiddleButtonAreaRight = 0
It appears that all options are being handled properly, except the RightButtonArea[...] ones. Looking at X logs gives me no clue about the problem, with no errors, only this:
[ 1499.416] (--) synaptics: ETPS/2 Elantech Touchpad: Vendor 0x2 Product 0xe
[ 1499.416] (**) Option "ClickPad" "1"
[ 1499.416] (**) Option "FastTaps" "1"
[ 1499.416] (**) Option "ClickFinger1" "1"
[ 1499.416] (**) Option "ClickFinger2" "3"
[ 1499.416] (**) Option "ClickFinger3" "2"
[ 1499.416] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
If I set them manually using synclient:
synclient RightButtonAreaLeft=2000
...then it works, but obviously I have to set manually them every time I start X.
Note that RightButtonAreaLeft depends on ClickPad=1 to work, although it is set correctly.
So it seems that the RightButtonArea[...] options are simply ignored by X. Like I said, I just reinstalled the system a few times before and it worked perfectly fine on every occasion.
Any help is greatly appreciated.
