How does Ubuntu come up with the default synaptics settings? I've got Ubuntu Netbook 10.10 installed on an Eeepc 900. Out of the box TapButton2 was set to 3, and TapButton3 was set to 2.
I have several custom synaptics settings I want as system wide defaults. Right now I use a script with synclient commands I have to run every boot or wake. Pita. It used to be everything went in xorg.conf..which no longer exists. I'm trying to learn the new way, which is apparently conf files at /usr/share/X11/xorg.conf.d.
I edited
/usr/share/X11/xorg.conf.d/50-synaptics.confto look like:Section "InputClass" Identifier "touchpad catchall" Driver "synaptics" MatchIsTouchpad "on" MatchDevicePath "/dev/input/event*" Option "LockedDrags" "1" Option "TapButton2" "2" Option "TapButton3" "3" EndSectionI tried modifying the touchpad section of
/usr/share/X11/xorg.conf.d/10-evdev.conf, no cigar.Tried the same 50-synaptics.conf and 10-evdev.conf files in a
/etc/X11/xorg.conf.dsection.Tried making a
/etc/X11/xorg.confwith the InputClass section above. No cigar.
I always revert the old change first, make the new one, and start a new X session to test (startx -- :2). Something I find interesting is that after any switch to the virtual terminal (ctrl+alt+F1) my synaptics settings are lost. Significant? I don't know.
These are the synclient commands I run:
jake@clyde:~$ cat bin/synset.sh #!/bin/bash synclient TapButton2=2 synclient TapButton3=3 synclient LockedDrags=1
Here is what's in /dev/input:
jake@clyde:/dev/input$ ls
by-path/ event0 event1 event2 event3 event4 event5 event6 event7 mice mouse0
jake@clyde:/dev/input$ ls -l by-path/
total 0
lrwxrwxrwx 1 root root 9 2011-02-18 15:43 platform-eeepc-event -> ../event6
lrwxrwxrwx 1 root root 9 2011-02-18 15:43 platform-i8042-serio-0-event-kbd -> ../event4
lrwxrwxrwx 1 root root 9 2011-02-18 15:43 platform-i8042-serio-1-event-mouse -> ../event7
lrwxrwxrwx 1 root root 9 2011-02-18 15:43 platform-i8042-serio-1-mouse -> ../mouse0
The X log is rather long, but here's some output. If the whole thing would be useful, where is a good place to upload it?
jake@clyde:/var/log$ egrep "synaptics|touchpad" Xorg.0.log
[ 16.707] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event7)
[ 16.707] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 16.707] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad catchall"
[ 16.707] (II) LoadModule: "synaptics"
[ 16.707] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 16.707] (II) Module synaptics: vendor="X.Org Foundation"
[ 16.708] (II) Synaptics touchpad driver version 1.2.2
[ 16.708] (II) ETPS/2 Elantech Touchpad: x-axis range 8 - 1144
[ 16.708] (II) ETPS/2 Elantech Touchpad: y-axis range 8 - 760
[ 16.708] (II) ETPS/2 Elantech Touchpad: device does not report pressure, will use touch data.
[ 16.708] (II) ETPS/2 Elantech Touchpad: finger width range 0 - 0
[ 16.708] (II) ETPS/2 Elantech Touchpad: buttons: left right double triple
[ 16.708] (--) ETPS/2 Elantech Touchpad: touchpad found
[ 16.708] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 16.708] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD)
[ 16.708] (**) ETPS/2 Elantech Touchpad: (accel) keeping acceleration scheme 1
[ 16.709] (**) ETPS/2 Elantech Touchpad: (accel) acceleration profile 0
[ 16.709] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 16.709] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 16.709] (--) ETPS/2 Elantech Touchpad: touchpad found
[ 16.710] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 15516.377] (--) ETPS/2 Elantech Touchpad: touchpad found
[ 44215.009] (--) ETPS/2 Elantech Touchpad: touchpad found
[ 44358.733] (--) ETPS/2 Elantech Touchpad: touchpad found
[ 44414.761] (--) ETPS/2 Elantech Touchpad: touchpad found
[ 44515.817] (--) ETPS/2 Elantech Touchpad: touchpad found
It looks like this remains unresolved in current Ubuntus (12.04, 12.10).
