96
I am a little confused on the proper fstab entry for a samba share in Ubuntu 12.04
  • I can get the drive to mount manually by using:
    sudo mount -t cifs //192.168.2.2/raid_drive /mnt/homeserver -o username=jon,password=password
  • So I tried putting this in fstab:
    //192.168.2.2/raid_drive /mnt/homeserver cifs username=jon,password=password,iocharset=utf8,mode=0777,dir_mode=07‌​77 0 0
  • Which gives me this error in syslog:
    kernel: [ 2217.925354] CIFS: Unknown mount option mode
    kernel: [ 2217.936345] CIFS VFS: default security mechanism requested.  The default security mechanism will be upgraded from ntlm to ntlmv2 in kernel release 3.3
  • This guide says to use smbfs although I believe smbfs is deprecated?
What is a common fstab configuration for a samba share in Ubuntu 12.04?
EDIT:
Using the accepted answer below I was initially getting this error message (from dmesg):
[   45.520883] CIFS VFS: Error connecting to socket. Aborting operation
[   45.520990] CIFS VFS: cifs_mount failed w/return code = -115
although it turns out this was due to network connectivity issues, and not related to improper fstab entry.
Jorge Castro
  • 73,717
jpetersen
  • 5,629
I've been through exactly this same issue this morning with 12.04 and here's how I got it working:
Install cifs-utils Install smbfs (even if you already have Samba and related packages installed):
sudo apt-get install cifs-utils
Edit /etc/fstab and add your entry:
//server/share /pathto/mountpoint cifs credentials=/home/username/.smbcredentials,uid=shareuser,gid=sharegroup 0 0
Create the .smbcredentials file in your home directory:
username=shareuser
password=sharepassword
domain=domain_or_workgroupname
Make sure you secure your ~/.smbcredentials file:
chmod 0600 ~/.smbcredentials
Finally, test the mount with:
sudo mount -a
...and you should be good to go!
russnash
  • 1,616
Your initial problem is in the option mode, as syslog says in the first line. What you probably meant was file_mode, see man mount.cifs for more information.
The credential approach mentioned by Eliah is indeed better than using username and password, but I don't think it interferes with the other options like file_mode or dir_mode.
Eric Carvalho
  • 55,453
Vitor
  • 51
