How to get parent PID from a given child's PID?
I know I can manually check it under /proc, I wonder if there is a smart/better way to achieve this in Ubuntu. Note the parent may or may not be killed.
Thanks
Thanks
Use ps -o ppid=
ps -o ppid= 2072 returns 2061, which you can easily use in a script etc. ps -o ppid= -C foo gives the PPID of process with command foo. You can also use the old fashioned ps | grep: ps -eo ppid,comm | grep '[f]oo'.ps -f 2072 returns
UID PID PPID C STIME TTY STAT TIME CMD izx 2072 2061 0 07:16 ? S 0:00 /usr/lib/pulseaudio/pulse/gconf-helper
pstree relation is: pstree -s -p 2072:
init(1)───pulseaudio(2061)───gconf-helper(2072)
echo $PPID
if you need the command from this parent pid:
cat /proc/$PPID/comm
if you need the full command line (with all options):
cat /proc/$PPID/cmdline
$PPID is defined by the shell, it's the PID of the parent process/proc/, you have some dirs with the PID of each processes. Then, if you cat /proc/$PPID/comm, you echo the command name of the PIDpstree by command nameUsing pstree you can search by the child process name and get the Process ID (PID) along with the parents, grandparents and any children of the child process:
$ pstree -hp | grep sleep
|-cron(763)---cron(795)---sh(839)---display-auto-br(841)---sleep(8414)
In this case sleep is the child command and it's PID is 8414. It's parent ID is 841 and is called display-auto-brightness. The grandparent is a shell (sh) with a process ID of 839. The great-grandparent is cron with a process ID of 795. The great-great-grandparent is also cron with a process ID of 763.
If you want to search by Process ID of sleep instead of name you can use:
$ pstree -hp | grep 14653
|-cron(763)---cron(795)---sh(839)---display-auto-br(841)---sleep(14653)
Notice the sleep process ID changed to 14653. The parent (PID 841) sleeps for 1 minute, wakes up for a split second and then starts a new sleep command which gets a new process ID. This is another reason why searching for sleep is easier than searching by process ID.
This code was taken from: Automatically adjust display brightness based on sunrise and sunset and adapted to this question.
To see a nested chain all the way back to boot process use the PID instead of name:
$ pstree -aps 8541
systemd,1 splash fastboot kaslr
└─cron,763 -f
└─cron,795 -f
└─sh,839 -c /usr/local/bin/display-auto-brightness
└─display-auto-br,841 /usr/local/bin/display-auto-brightness
└─sleep,8541 60
Note: Another minute has passed and the sleep command gets a new PID (8541).
ps -efj can also be used for the same.
For example,
> ps -efj | head
UID PID PPID PGID SID C STIME TTY TIME CMD
root 1 0 1 1 0 Jul01 ? 00:00:13 /sbin/init splash
root 2 0 0 0 0 Jul01 ? 00:00:00 [kthreadd]
root 3 2 0 0 0 Jul01 ? 00:00:02 [ksoftirqd/0]
root 5 2 0 0 0 Jul01 ? 00:00:00 [kworker/0:0H]
root 7 2 0 0 0 Jul01 ? 00:06:44 [rcu_sched]
root 8 2 0 0 0 Jul01 ? 00:00:00 [rcu_bh]
root 9 2 0 0 0 Jul01 ? 00:00:00 [migration/0]
root 10 2 0 0 0 Jul01 ? 00:00:08 [watchdog/0]
root 11 2 0 0 0 Jul01 ? 00:00:08 [watchdog/1]
If you want id of the process that launched your shell, just use environment variable PPID. For example
echo $PPID
If you have a process id without any relation to your current shell, you can get the parent id (in environment variable PID with one of the following commands:
awk '{print $4}' < /proc/$PID/stat
ps -o "ppid=" $PID
read ignore ignore ignore PARENT_PID ignore < /proc/$PID/stat ; echo $PARENT_PID
The last one can be executed without creating a new process but it pollutes the environment with new variabled called ignore in addition to setting $PARENT_PID to correct value.
