14
I have a script which runs whenever I open the terminal (I put the command in .bashrc). Now when I open Visual Studio Code the script is obviously also executed in the internal terminal therein. I don‘t want this to happen. Is there any way to detect whether a terminal instance was started by VSCode so I can prevent the script from executing in that case? (I use bash)
Sorry if this is a dumb question, I am still fairly new to Linux and bash.
VS Code sets the standard environment variable TERM_PROGRAM in the terminal's environment to indicate what launched it, so you can solve your problem using this without needing to parse the process tree:
if [[ "$TERM_PROGRAM" == "vscode" ]]; then
  exit 0
fi
Rest of script...
The one exception to this rule is if an extension creates a terminal and specifies the seldom used strictEnv flag. These are shells that the extension indicated it wants complete control over the environment.
Using this potentially duplicate answer: https://askubuntu.com/a/1012277/307523
rick@alien:~$ echo $$
25119
rick@alien:~$ pstree -aps $$
systemd,1 splash fastboot kaslr
  └─lightdm,1026
      └─lightdm,1294 --session-child 12 19
          └─upstart,1838 --user
              └─gnome-terminal-,25109
                  └─bash,25119
                      └─pstree,5696 -aps 25119
The environment variable $$ returns the current running processes PID (Process ID) which is the bash terminal.
The pstree command shows the entire "tree" of commands called.
