Ok so I am trying to fix a broken package in order to install wine. When I do "sudo apt-get install wine" I get:
sam@ubuntu:~$ sudo apt-get install wine
[sudo] password for sam:
Reading package lists... Done
Building dependency tree
Some packages could not be installed.
This may mean that you have requested an impossible situation or if you are
using the unstable distribution that some required packages have not yet
been created or been moved out of Incoming.
  wine : Depends: wine1.4 but it is not going to be installed
Then I try "sudo apt-get install wine1.4"
sam@ubuntu:~$ sudo apt-get install wine1.4
 wine1.4 : Depends: wine1.4-i386 (= 1.4.1-0ubuntu1) but it is not installable
           Recommends: gnome-exe-thumbnailer but it is not going to be installed or
                       kde-runtime but it is not going to be installed
           Recommends: winetricks but it is not going to be installed
So someone told me to try Synaptic. Here is what I tried:
  1. Searched wine
  2. Right clicked wine1.4
  3. Said I needed to mark other packages
  4. Mark
  5. I click Apply. It says, You have to fix broken packages first!
  6. I do Edit>Fix Broken Packages I get this
    E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
    E: Unable to correct dependencies
I am really frustrated. I removed the Official Wine PPA and tried it I even tried
$ sudo apt-get -f install
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Please help me :(
System: Ubuntu 12.10 64bit
Tim
  • 33,500
This is a common problem with Wine and 64bit systems. The solutions proposed here solves de problem:
