I am using 12.04 LTS dual boot, and I can't use the bluetooth service in Ubuntu. It works fine with Windows 7. In Ubuntu I can turn on the bluetooth from the titlebar but when I switch on the visibility it automatically switches back (I'm using GNOME 3 environment).
All this happened after the 1st update (worked fine before then).
tshepang
  • 2,007
7 Answers7
21
Found an easier solution than reseting BIOS!
sudo hciconfig hci0 reset
bluetooth was enabled on ubuntu 12.04.
I could do file transfer between Nexus7 and my laptop. but nexus7 stopped playing music and laptop started playing music!
Jorge Castro
  • 73,717
I've got the same issue, and it turned out that Bluetooth was turned off in windows... If you use both windows and ubuntu on the same machine, try this command:
rfkill list all
If it says that Bluetooth is soft blocked then try to enable it on windows and then check again if it works on ubuntu also.
maciekb
  • 41
I got this problem since I installed 12.04. I have tried many ways to install bluetooth, then changing if my bluetooth is soft blocked or not, then reinstall my bluetooth software on Ubuntu I had done it all.
But I found the BEST WAY to enable bluetooth with:
  1. Restart your Ubuntu
  2. Go to BIOS program (through Del or F2 - its optional based on your computer)
  3. Set the BIOS to 'reset to factory setting' usually using F9 or else its based on your type of BIOS
  4. Startup, then go to your bluetooth you will found that your bluetooth wont disabled again.
Good luck.
Peachy
  • 7,235
  • 40
  • 47
Just had this problem (on 12.10), solution I found: kill blueman-applet and start it again. Run blueman-applet & from a terminal to start it.
Eric Carvalho
  • 55,453
Lucus
Check your bluetooth device ,see if the bluetooth is switched off by hardware switch. If that is the case, turn the bluetooth hardware switch on.
Muhammad
  • 321
Setting to Factory Defaults helped me instantly with the Wireless and Bluetooth. They were shutdown in Ubuntu 13.04 for me.
-2
sudo apt-get install linux-firmware
Eliah Kagan
  • 119,640
