Bluetooth doesn't work anymore on my HP 8560w.
Systems Settings show "No Bluetooth Found, Plug in a dongle to use Bluetooth".
And yes, the one switch that controls both Wifi and Bluetooth is enabled. And Airplane mode is off, too!
Note that Bluetooth did work in the past on that machine, but since I didn't use BT for some time, I don't know when it broke (nor what update broke it).
And no track of a blutooth error in kern.log or syslog.
I ran and uploaded a probe to linux-hardware.org, and the host section shows that the detected hardware is an "HP, Inc Broadcom 2070 Bluetooth Combo" and that the required driver is btusb:
USB 03f0:231d / e0-01-01 HP,Inc Broadcom 2070 Bluetooth Combo bluetooth btusb detected
Running lsmod:
$ sudo lsmod
Upon boot:
result: No bt* driver module that I can see in the list.
After running
sudo modprobe btusb,
I get
Module Size Used by
btusb 57344 0
btrtl 24576 1 btusb
btbcm 16384 1 btusb
btintel 24576 1 btusb
btbcm is described as "Bluetooth support for Broadcom devices".
So btusb has loaded, and its (hardware) dependencies too.
But I still have Systems Settings showing
No Bluetooth Found - Plug in a dongle to use Bluetooth.
I have looked at the various "similar questions" suggested by ask ubuntu, particularly:
Trouble turning on bluetooth in 12.04
but didn't find any suitable (and/or working) clue for 20.04.6.
I also googled around to, and found nothing that would solve it.
Does anyone know why btusb (and dependencies) are not autoloaded anymore at boot in myUbuntu 20.04.6 LTS, or how to find out?
As a side question, I wonder why the system still doesn't see Bluetooth hardware after I manually load the proper driver?...
$ sudo hcitool scan
Device is not available: No such device
