-2
Background
Ubuntu 24.04 crashed - unable to automount SSD after force restart
I have tried sudo ntfsfix /dev/sdd but it not work.
Disk check and repair in Windows11 can solve the problem, maybe windows use chkdsk command. but how repair in ubuntu.
update:
following :
I tried his command and get below info:
sudo e2fsck -c /dev/sdd
[sudo] password for user-name:
e2fsck 1.47.0 (5-Feb-2023)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/sdd
The superblock could not be read or does not describe a valid ext2/ext3/ext4 filesystem. If the device is valid and it really contains an ext2/ext3/ext4 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> or e2fsck -b 32768 <device>
Found a dos partition table in /dev/sdd
And I also tried sudo fsck -f /dev/sdd1 and reboot, it not work.
BTW: I don't have enough prestige to comment. So I have to open a new asking.
chkdsk software is not compatible with Ubuntu.
It cannot be run on an Ubuntu system.
user535733
  • 68,493
