86
I installed Visual Studio Code a while ago, and I'm now trying to remove it. I don't remember how I installed it, but everything I've tried to remove it doesn't work. Things I've tried:
  1. sudo umake web visual-studio-code --remove: This says "can't remove because you don't have it installed," which I know isn't true. I was able to find the files in /home/jacob/.local/share/umake/web/visual-studio-code. Deleting those files, by the way, stops the application from running, but doesn't remove the icon from the launcher. I restored the files once I figured that out.
  2. Removing via Software Center: It does show up in Software Center, but when I hit "remove" nothing happens.
Any other suggestions?
JacobTheDev
  • 1,169
10 Answers10
128
I did it with the following command:
sudo apt purge code
to uninstall the program and then:
sudo apt autoremove
to remove the menu items/shortcuts etc as @Joe suggested.
I hope it helps!
Edit: You can also check @Felix's comment and remove the vscode folders:
rm -rf ~/.vscode ~/.config/Code
haralambov
  • 1,604
18
As none of the above answer has been accepted so I am assuming it didn't solve your problem. If you cannot find it with apt or dpkg then most likely it was installed with snap as was in my case. To remove it just type:
snap remove code
13
sudo dpkg --remove visual-studio-code
This will remove the software (including the Dash icon/desktop entry).
I think that this method will leave the configuration information around (if you re-install); there's also a purge option on dpkg that will remove this information as well.
sudo dpkg --purge visual-studio-code
I had to update VS Code from the Software Center to uninstall it properly. -_-
After that, this worked perfectly:
sudo apt-get purge code
Kendra Havens
  • 71
I was running into the very same problem today. None of the provided answers solved it for me. So I tried:
$ which visual-studio-code
/home/tim/.local/share/umake/bin/visual-studio-code
I was having a look at that directory and realized it was a symlink to
/home/tim/.local/share/umake/bin/visual-studio-code ->
/home/tim/.local/share/umake/ide/visual-studio-code/bin/code*
So I was able to remove it with
umake ide visual-studio-code --remove
(Note how I use umake ide and not umake web)
I find this command from http://tipsonubuntu.com/2017/03/03/install-ms-visual-studio-code-ubuntu-16-0416-10/ and it work for me.
sudo apt remove code && sudo apt autoremove
David Foerster
  • 36,890
  • 56
  • 97
  • 151
For all of them like me, code or visual-studio-code didn't work try using, vscode.
Classic
sudo apt purge code && sudo apt autoremove
Do not forget
rm -fr ~/.vscode (That was taking a good 500M on my machine)
If you have installed it with umake, chances are that you didn't use sudo in front of it, so to remove it just type in umake web visual-studio-code --remove. That's it.
sudo apt-get purge --auto-remove code
This should remove the files (of visual-studio-code), its configuration files and the dependencies.
thisisjab
  • 105
ankit7540
  • 4,195
