I'm using Windows dual booting with Ubuntu.
I have uninstalled, and at that time my disk was formated as MBR. After deleting all partitions of Ubuntu I choose to rebuild the MBR in my disk. That way I was sure not to loose the Windows boot loader.
Now I'm using a GPT disk. I want to delete Ubuntu but I'm scared I will loose my Windows boot loader.
Press Win + R to get the run box, type diskmgmt.msc and press enter.
  • Just click with right mouse button on the Ubuntu partition, and choose to Delete Volume.
  • If Windows 8.1 was preinstalled on your computer, please ensure you don't remove recovery partitions, etc.
  • The space formerly occupied by Linux should now say "Unallocated".
  • And Now Right-click on C: and "Extend Volume" to increase the size of drive C using the unallocated space.(NOTE: You can replace any drive letter instead of C: that you shrink it before for installing Ubuntu)
  • If you were using grub to dual-boot (most probably), then you may need the windows 8.1 CD to fix the boot manager and make Windows 8.1 bootable again.
How to fix your boot manager :
  1. boot your system using windows 8.1 installation CD or flash drive
  2. go to "repair your system"
  3. use command prompt (Troubleshoot ► Advanced Options ► Command Prompt)
  4. type bootrec /fixboot then hit enter
  5. type bootrec /fixmbr then hit enter
  6. exit
This time your system will boot directly into windows.
This is the safe way to uninstall Ubuntu.
danijar
  • 656
αғsнιη
  • 36,350
