Issue
As the OP has stated, I can safely assume that no Internet Application that requires a DNS lookup to "travel" anywhere on the internet works. I posted some comments about what the possibilities for the cause could be but after Googling for snap package firefox does not connect to internet decided against trying to track down the cause. The general consensus in all of the results was that Snap and it's mechanisms have some issues. I thought about letting someone else tackle this question until I realized: Even though Canonical has chosen this as a strategic design decision, maybe we can turn it off. And now I present the rather involved procedure:
Removing Snap Packages
- First, we make sure it's installed as a sanity test:
snap --version
- Now let's gather which snap packages are installed as part of the core:
snap list. Write all these down or > them to a file to print as we're going to remove them shortly.
- To remove, issue:
snap remove followed by the package name from the output in step 2.
- To verify that the entire list is removed, reissue a
snap list. As your final output, you should see: snap list
No snaps are installed yet. Try 'snap install hello-world'.
Removing Snap Daemon
- Stop SystemD Service:
sudo systemctl stop snapd
- Disable the Service:
sudo systemctl disable snapd
- Mask the Service:
sudo systemctl mask snapd
- Masking a service symlinks it to
dev/null. This effectively sends every call for a restart etc to oblivion
- Uninstall snapd:
apt remove snapd -y
- Hold the package in the removed state during upgrades and installs:
sudo apt-mark hold snapd
Remove Leftover Cruft
With Snapd now removed, we can clean up the mess left by configuration files etc.
- Remove Snap Cruft:
rm -rf ~/snap
sudo rm -rf /snap
sudo rm -rf /var/snap
sudo rm -rf /var/lib/snapd
Turn off the APT wrapper
Create the nosnap preferences file. This will keep APT from pulling in Snap itself:
## Thank Linux Mint for this jewel.
## See: https://linuxmint-user-guide.readthedocs.io/en/latest/snap.html
sudo cat <<EOF | sudo tee /etc/apt/preferences.d/nosnap.pref
Package: snapd
Pin: release a=*
Pin-Priority: -10
EOF
The above preferences file globs all snap package versions installed by APT and drops the priority below 0. This ensures APT will never install snapd.
Sanity Test
To make sure we've completed our modifications correctly, let's try installing Chromium which is only available as a Snap Package:
sudo apt install chromium-browser
Reading package lists... Done
Building dependency tree... Done
chromium-browser : PreDepends: snapd but it is not installable
Now What??
Well we need a browser or two, plus all the packages we removed. For the purposes of this answer, I'm going to link to Chromium and Firefox but Googling for install <package> not snap ubuntu should find plenty of results for whatever <package> needed.
- Install Firefox not snap
- How to install Chromium without snap? - Replace Eoan with Buster
As the DebugPoint link suggests, always use --install-suggests to prevent installing snap packages by accident. In most cases, you should get the warning like Chromium above, but it's always better to be safe than sorry.
Note: While mixing distributions isn't recommended, it's now our only choice since we have totally disabled the Snap packaging mechanic. See: Don't Make a Frankendebian. Generally speaking, never mix two main repositories. I expect that since you're only installing Apps that a Frakendebian will not be created.
PS. Since Snap is now disabled, you're free to investigate the DNS issue that caused this. After you find it, I would report a bug to the offending package maintainers, fix as they advise and then reverse this fix. At some point the ability to prevent APT from using Snapd may be removed. As a starting point, I would consider doing a clean install of 22.04 on an extra PC/laptop and do a staged upgrade path like I commented. You can't use a VM on your current install as we fixed the broken parts before we installed a VM, which defeats the troubleshooting.
