Try uninstalling the installed version and installing the latest stable version of Firefox from the developer packages.
To do this, open a terminal and:
To remove the installed version of Firefox, run the following commands in a terminal (execute them one by one):
sudo apt remove --purge firefox*
sudo snap disable firefox
sudo snap remove --purge firefox
sudo apt update
sudo apt install --reinstall wget
sudo apt autoremove
sudo apt clean
Then, to download the latest version of Firefox, run the following commands in the terminal:
cd ~/Downloads
wget https://ftp.mozilla.org/pub/firefox/releases/137.0.2/linux-x86_64/en-GB/firefox-137.0.2.tar.xz
Once the file has been downloaded, in the 'Downloads' folder.
Extract the file using the following command:
tar -Jxvf firefox-136.0.1.tar.xz
We should now have an extracted folder called firefox.
You need to move the folder to /opt with the following command:
sudo mv firefox /opt
Now, a link must be created to start Firefox .
Running the following command to create the link to Firefox
sudo ln -s /opt/firefox/firefox /usr/bin/firefox
