I'm using Xubuntu 12.04. How do I either swap or remap the Control (or any key) and Caps Lock keys?
Another way:
sudo vi /etc/default/keyboard
then find the line that starts with XKBOPTIONS, and add ctrl:nocaps to make Caps Lock an additional Control key or ctrl:swapcaps to swap Caps Lock and Control.
For example, mine looks like
XKBOPTIONS="lv3:ralt_alt,compose:menu,ctrl:nocaps"
then run
sudo dpkg-reconfigure keyboard-configuration
The reason this way is better is that it will take effect on the virtual consoles (e.g. Ctrl+Alt+F1) as well as in the graphical desktop.
- 6,615
To swap the keys go:
Xubuntu → Settings Manager → Session and Startup
Then in the Sessions and Startup configurator go
Application Autostart (tab at the top) → Add (bottom button)
Now on the Add Application screen
- Name: Control and CapsLk swap
- Description: Swap the two keys
- Command: /usr/bin/setxkbmap -option "ctrl:swapcaps"
To remap Caps Lock to Control go:
Name: Remap CapsLk to Ctrl
Description: Remap the CapsLk key to Control
Command: /usr/bin/setxkbmap -option "ctrl:nocaps"
- 7,703
For compose instead of caps put compose:caps as the -options parameter.
- 119,640
- 31
For Raring (at least):
Start "Keyboard layout" (from dash).
Press "Options..." to reach "Keyboard layout options" menu.
I chose "Ctrl key position" => "Caps lock as Ctrl". Your tastes may differ.
- 29
