I'm trying to remap my CapsLock key to Ctrl key as described here (adding /usr/bin/setxkbmap -option "ctrl:nocaps" command to "Session and Startup"->"Application Autostart").
But this doesn't work in Xubuntu 12.04.
When I'm running the same command (/usr/bin/setxkbmap -option "ctrl:nocaps") from terminal everything works as expected. If I change command to: sh -c "/usr/bin/setxkbmap -option \"ctrl:nocaps\"" it again works if I'm running it from terminal, but it doesn't work if I add it to xfce "Session and Startup" configurator. Also when I create a script like this:
#!/bin/sh
and add it to startup via "Session and startup" configurator, it has no effect at all. But if I run this script after login it actually remaps caps key as expected.
Evgeny
  • 81
OK, my problem was because of xfce4-xkb-plugin. It was resetting xkb settings each time. I just installed xxkb instead of it, and now everything works absolutely fine!
ish
  • 141,990
Evgeny
  • 81
