I'm trying to follow my own installation instructions here: USB to HDMI adapter that works with Ubuntu. They work great on Ubuntu 22.04, but not 20.04. On 20.04 when I do the sudo apt install displaylink-driver step, I get:
$ sudo apt install displaylink-driver
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: displaylink-driver : Depends: evdi (>= 1.14.1) but it is not going to be installed Depends: evdi (< 1.15.0) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
This answer recommends sudo apt install evdi-dkms.
That results in more errors:
Building initial module for 5.15.0-41-generic
ERROR (dkms apport): kernel package linux-headers-5.15.0-41-generic is not supported
Error! Bad return status for module build on kernel: 5.15.0-41-generic (x86_64)
Consult /var/lib/dkms/evdi/1.6.0+dfsg/build/make.log for more information.
dpkg: error processing package evdi-dkms (--configure):
 installed evdi-dkms package post-installation script subprocess returned error exit status 10
Setting up libevdi0 (1.6.0+dfsg-1ubuntu3) ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
 evdi-dkms
Full context:
$ sudo apt install evdi-dkms
The following additional packages will be installed:
  libevdi0
The following NEW packages will be installed:
  evdi-dkms libevdi0
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 34.4 kB of archives.
After this operation, 173 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://us.archive.ubuntu.com/ubuntu focal/universe amd64 evdi-dkms all 1.6.0+dfsg-1ubuntu3 [25.5 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu focal/universe amd64 libevdi0 amd64 1.6.0+dfsg-1ubuntu3 [8,972 B]
Fetched 34.4 kB in 0s (74.8 kB/s)
Selecting previously unselected package evdi-dkms.
(Reading database ... 499689 files and directories currently installed.)
Preparing to unpack .../evdi-dkms_1.6.0+dfsg-1ubuntu3_all.deb ...
Unpacking evdi-dkms (1.6.0+dfsg-1ubuntu3) ...
Selecting previously unselected package libevdi0.
Preparing to unpack .../libevdi0_1.6.0+dfsg-1ubuntu3_amd64.deb ...
Unpacking libevdi0 (1.6.0+dfsg-1ubuntu3) ...
Setting up evdi-dkms (1.6.0+dfsg-1ubuntu3) ...
Loading new evdi-1.6.0+dfsg DKMS files...
Building for 5.15.0-41-generic
 evdi-dkms
And now sudo apt install installs on anything else. And sudo apt upgrade fails with this:
$ sudo apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Removing old evdi-1.6.0+dfsg DKMS files...
Deleting module version: 1.6.0+dfsg completely from the DKMS tree.
Done. Loading new evdi-1.6.0+dfsg DKMS files... Building for 5.15.0-41-generic Building initial module for 5.15.0-41-generic ERROR (dkms apport): kernel package linux-headers-5.15.0-41-generic is not supported Error! Bad return status for module build on kernel: 5.15.0-41-generic (x86_64) Consult /var/lib/dkms/evdi/1.6.0+dfsg/build/make.log for more information. dpkg: error processing package evdi-dkms (--configure): installed evdi-dkms package post-installation script subprocess returned error exit status 10 Errors were encountered while processing: evdi-dkms E: Sub-process /usr/bin/dpkg returned an error code (1)
So I run sudo dpkg -r evdi-dkms, per my comment here to fix that, and I'm back at the beginning again. sudo apt upgrade works again, thank goodness!--whew! But, sudo apt install displaylink-driver is right back to the error at the beginning.
I tried upgrading to Ubuntu 22.04, and /boot is too full.
Note: from the sudo apt install evdi-dkms failure messages above, it says to:
Here's what is in that file:
From /var/lib/dkms/evdi/1.6.0+dfsg/build/make.log:
DKMS make.log for evdi-1.6.0+dfsg for kernel 5.15.0-41-generic (x86_64)
Thu 28 Sep 2023 07:05:36 PM MST
make: Entering directory '/usr/src/linux-headers-5.15.0-41-generic'
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_drv.o
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_connector.o
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_modeset.o
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_encoder.o
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_main.o
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_fb.o
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_gem.o
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_drv.c:11:10: fatal error: drm/drmP.h: No such file or directory
   11 | #include <drm/drmP.h>
compilation terminated.
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_drv.o] Error 1
make[1]: *** Waiting for unfinished jobs....
  CC [M]  /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_painter.o
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_connector.c:14:10: fatal error: drm/drmP.h: No such file or directory
   14 | #include <drm/drmP.h>
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_modeset.c:15:10: fatal error: drm/drmP.h: No such file or directory
   15 | #include <drm/drmP.h>
make[1]: *** [scripts/Makefile.b<drm/drmP.h>uild:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_modeset.o] Error 1
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_connector.o] Error 1
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_encoder.c:14:10: fatal error: drm/drmP.h: No such file or directory
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_encoder.o] Error 1
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_gem.c:11:10: fatal error: drm/drmP.h: No such file or directory
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_gem.o] Error 1
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_main.c:15:10: fatal error: drm/drmP.h: No such file or directory
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_main.o] Error 1
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_painter.c:12:10: fatal error: drm/drmP.h: No such file or directory
   12 | #include <drm/drmP.h>
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_painter.o] Error 1
/var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_fb.c:20:10: fatal error: drm/drmP.h: No such file or directory
   20 | #include <drm/drmP.h>
make[1]: *** [scripts/Makefile.build:285: /var/lib/dkms/evdi/1.6.0+dfsg/build/evdi_fb.o] Error 1
make: *** [Makefile:1875: /var/lib/dkms/evdi/1.6.0+dfsg/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.15.0-41-generic'
So apparently I'm missing the <drm/drmP.h> header file if anyone knows how to get that.
The evdi source code seems to be here: https://github.com/DisplayLink/evdi
I was unable to build it from scratch. make fails with another missing header file.
(And this is why people use Windows, friends).
I'm trying to install libdrm-dev, per these instructions: How to install DisplayLink software on Ubuntu 20.04 or (newer) How to install DisplayLink software on legacy Ubuntu versions
...but that doesn't work either.
New question: Cannot install libdrm-dev on Ubuntu 20.04 because it requires dependencies which are older than what I have
If I manually build and install libdrm from source, per my answer here, and then manually try to install the DisplayLink driver, the installer still blocks me:
~/Downloads/Install_Files/DisplayLink/DisplayLink USB Graphics Software for Ubuntu5.8-EXE$ sudo ./displaylink-driver-5.8.0-63.33.run
Verifying archive integrity...  100%   MD5 checksums are OK. All good.
Uncompressing DisplayLink Linux Driver 5.8.0-63.33  100%
Distribution discovered: Ubuntu 20.04.4 LTS
[ Installing dependencies ]
Need to update package list.
apt update? (Y/n) n
Unsatisfied dependencies. Missing component: libdrm.
This is a fatal error, cannot install DisplayLink Linux Software.
See also
  1. Problems installing DisplayLink Driver on Ubuntu 20.04
  2. Can't install Synaptics displaylink-driver on Ubuntu 22.04
Gabriel Staples
  • 11,502
  • 14
  • 97
  • 142
Full instructions: installing displaylink-driver on Ubuntu 20.04 (also applies to 22.04 or later)
Note: these instructions also apply to Ubuntu 22.04 or later. The only part here that was specific to Ubuntu 20.04 was using sudo aptitude install libdrm-dev to install libdrm-dev, since sudo apt install libdrm-dev didn't work. @Stefan Buynov says that was required for him on Ubuntu 24.04 too, however, and that he had to manually install aptitude.
I figured out a way! I got libdrm-dev installed by using aptitude:
# then choose these options:
n  # do NOT leave things as-is
y  # DO downgrade dependencies
y  # Do continue with the install
See my full answer, output, and description here: Cannot install libdrm-dev on Ubuntu 20.04 because it requires dependencies which are older than what I have
Then, once I had libdrm-dev successfully installed, installing the dependencies per the official instructions here worked: How to install DisplayLink software on legacy Ubuntu versions:
sudo apt update
sudo apt dist-upgrade
sudo apt install dkms
sudo apt install libdrm-dev  # already installed by aptitude above, but running
                             # this command again doesn't hurt
And then my instructions in my answer here worked: USB to HDMI adapter that works with Ubuntu:
Disable Secure Boot in the BIOS, then reboot, and run the following:
# Make this directory if it doesn't exist, and cd into it
mkdir -p ~/Downloads/Install_Files/DisplayLink
cd ~/Downloads/Install_Files/DisplayLink
Download the Ubuntu APT package provided by Synaptics.com, the official
makers of DisplayLink
wget https://www.synaptics.com/sites/default/files/Ubuntu/pool/stable/main/all/synaptics-repository-keyring.deb
Install the DisplayLink APT package keyring
sudo apt install ./synaptics-repository-keyring.deb
Update your APT package cache
sudo apt update
Install the DisplayLink driver provided by Synaptics.com, the official source
Reboot.
Now it is plug-and-play. Plug in your DisplayLink adapter and it just works.
It may take up to 5~10 seconds to recognize a monitor.
Done!
After rebooting, you can plug in your $90, Club3D CSV-1477 USB 3.0 Type A to Dual Display Port 1.2 4K 60Hz External Graphics Video Adapter, for instance, and it will be recognized in 5 to 10 seconds or so and automatically begin displaying up to two simultaneous 4k at 60 Hz outputs over USB 3.0 USB-A plugs.
In case you're interested, here is my full output when I ran sudo apt install displaylink-driver. Notice that it explicitly told me to reboot:
[sudo] password for gabriel:
  evdi
  displaylink-driver evdi
Need to get 6,318 kB of archives.
Get:1 https://www.synaptics.com/sites/default/files/Ubuntu stable/main amd64 evdi amd64 1.14.1-7 [47.4 kB]
Get:2 https://www.synaptics.com/sites/default/files/Ubuntu stable/non-free amd64 displaylink-driver amd64 5.8.0-33 [6,271 kB]
Fetched 6,318 kB in 3s (1,981 kB/s)
Selecting previously unselected package evdi.
(Reading database ... 499730 files and directories currently installed.)
Preparing to unpack .../evdi_1.14.1-7_amd64.deb ...
Unpacking evdi (1.14.1-7) ...
Selecting previously unselected package displaylink-driver.
Preparing to unpack .../displaylink-driver_5.8.0-33_amd64.deb ...
Unpacking displaylink-driver (5.8.0-33) ...
Setting up evdi (1.14.1-7) ...
Creating symlink /var/lib/dkms/evdi/1.14.1/source -> /usr/src/evdi-1.14.1
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module: cleaning build area... make -j8 KERNELRELEASE=5.15.0-41-generic all INCLUDEDIR=/lib/modules/5.15.0-41-generic/build/include KVERSION=5.15.0-41-generic DKMS_BUILD=1..... Signing module:
  • /var/lib/dkms/evdi/1.14.1/5.15.0-41-generic/x86_64/module/evdi.ko
Secure Boot not enabled on this system. cleaning build area...
DKMS: build completed.
evdi.ko: Running module version sanity check.
  • Original module
    • No original module exists within this kernel
  • Installation
    • Installing to /lib/modules/5.15.0-41-generic/updates/dkms/
depmod....
DKMS: install completed.
Reboot required DisplayLink evdi module installed successfully. Please reboot your computer to ensure the proper functioning of the software.
Setting up displaylink-driver (5.8.0-33) ...
Reboot required DisplayLink driver installed successfully. Please reboot your computer to ensure the proper functioning of the software.
Other references
  1. My answer here: USB to HDMI adapter that works with Ubuntu - I talk about the results of using my $90, Club3D CSV-1477 USB 3.0 Type A to Dual Display Port 1.2 4K 60Hz External Graphics Video Adapter here.
  2. ***** Newer official info: How to install DisplayLink software on legacy Ubuntu versions
  3. Older official info: How to install DisplayLink software on Ubuntu 20.04
Gabriel Staples
  • 11,502
  • 14
  • 97
  • 142
