Can't install the Displaylink driver from Synaptics https://www.synaptics.com/products/displaylink-graphics/downloads/ubuntu
Below has a warning message dpkg: warning: files list file for package 'libc-bin' missing; assuming package has no files currently installed
followed by the first error at make: bad exit status: 2
sudo apt install displaylink-driver Reading package lists... Done
Building dependency tree... Done Reading state information... Done The
following additional packages will be installed:   evdi libdrm-dev
libpciaccess-dev The following NEW packages will be installed:
displaylink-driver evdi libdrm-dev libpciaccess-dev 0 to upgrade, 4 to
newly install, 0 to remove and 1 not to upgrade. Need to get 0 B/5,452
kB of archives. After this operation, 1,397 kB of additional disk
space will be used. Do you want to continue? [Y/n] y Selecting
previously unselected package libpciaccess-dev:amd64. dpkg: warning:
no files currently installed (Reading database ... 222433 files and
directories currently installed.) Preparing to unpack
.../libpciaccess-dev_0.16-3_amd64.deb ... Unpacking
libpciaccess-dev:amd64 (0.16-3) ... Selecting previously unselected
package libdrm-dev:amd64. Preparing to unpack
.../libdrm-dev_2.4.113-2~ubuntu0.22.04.1_amd64.deb ... Unpacking
libdrm-dev:amd64 (2.4.113-2~ubuntu0.22.04.1) ... Selecting previously
unselected package evdi. Preparing to unpack
.../evdi_1.13.1-18_amd64.deb ... Unpacking evdi (1.13.1-18) ...
Selecting previously unselected package displaylink-driver. Preparing
to unpack .../displaylink-driver_5.7.0-129_amd64.deb ... Unpacking
displaylink-driver (5.7.0-129) ... Setting up libpciaccess-dev:amd64
(0.16-3) ... Setting up libdrm-dev:amd64 (2.4.113-2~ubuntu0.22.04.1)
... Setting up evdi (1.13.1-18) ... Creating symlink
/var/lib/dkms/evdi/1.13.1/source -> /usr/src/evdi-1.13.1
Kernel preparation unnecessary for this kernel. Skipping...
Building module: cleaning build area... make -j4 KERNELRELEASE=5.15.0-78-generic all INCLUDEDIR=/lib/modules/5.15.0-78-generic/build/include KVERSION=5.15.0-78-generic DKMS_BUILD=1...(bad exit status: 2) ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/evdi.0.crash' Error! Bad return status for module build on kernel: 5.15.0-78-generic (x86_64) Consult /var/lib/dkms/evdi/1.13.1/build/make.log for more information. dpkg: error processing package evdi (--configure): installed evdi package post-installation script subprocess returned error exit status 10 dpkg: dependency problems prevent configuration of displaylink-driver: displaylink-driver depends on evdi (>= 1.13.1); however: Package evdi is not configured yet. displaylink-driver depends on evdi (<< 1.14.0); however: Package evdi is not configured yet.
dpkg: error processing package displaylink-driver (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. Processing triggers for man-db (2.10.2-1) ... Errors were encountered while processing: evdi displaylink-driver E: Sub-process /usr/bin/dpkg returned an error code (1)
This install worked ok on another ubuntu machine. Suspect the issue here is a couple of months ago I did the sudo ./displaylink-driver-x.x.x.xx.run install method. That install didn't work and gave up.
Gabriel Staples
  • 11,502
  • 14
  • 97
  • 142
I'm not quite sure how I got my laptop into this state, but installing evdi-dkms allowed the displaylink install to work OK finally, after trying to many things and consistently seeing EVDI related errors.
  • sudo apt install evdi-dkms
  • sudo apt install displaylink-driver
This fix was described on the displaylink forum.
I was struggling with installation myself. After trying everything I finally decided to undo everything by deleting the installed Displaylink driver and evdi (you can find help with that here How to uninstall DisplayLink Ubuntu software )
I then went to install everything from the beginning by following Synaptics instructions on how to install a standalone installer (you can find the installer here Ubuntu Driver Download)
Just follow the instructions from here: How to install DisplayLink software on legacy Ubuntu versions
After the installation, I needed to add MOK keys in BIOS for secure boot (the installation itself will guide you if you will need to add them) and now everything is working fine.
I hope this helps.
