Note, I do not meet the problem described below with Ubuntu 20.04.
Problem: After a "successful" installation of Ubuntu 22.04. I reboot my computer but it freezes on a black screen with this info written on it:
/dev/sda3: clean, 217199/2444624 files, 2561133/9765632 blocks
Installation process: Below I provided information on how I installed Ubuntu 22.04.
Specs: x86_64, NVIDIA GeForce RTX 3060
- Downloaded "ubuntu-22.04.2-desktop-amd64.iso" on this website https://ubuntu.com/download/desktop
- Used "Rufus" to create a bootable USB (partition scheme MBR)
- I used "Normal Installation" and "Install third-party software"
- Installing Ubuntu I created 4 partitions (ext4 root, ext4 home, EFI system partition, swap)
- Installed "successfully"
- Reboot
After I rebooted, I faced the problem that I described earlier. The computer does not respond at all.
My attempts at solving this problem: I tried to solve the problem by following the posts below, but they did not help. Mainly because I cannot do anything in recovery mode.
- "dev/sda1: clean, ..." This message appears after I startup my laptop, then it won't continue booting
- My computer boots to a black screen, what options do I have to fix it?
When I try to boot into recovery mode I get 2 options:
- Ubuntu, with Linux 6.2.0-26-generic (recovery mode)
- Ubuntu, with Linux 5.19.0-32-generic (recovery mode)
Neither one works.
On the recovery Menu, I choose "root".
When I try to do sudo apt update system returns W: Failed to fetch http:\\....
I connected to the internet via a LAN cable. So, I'm pretty sure that computer has access to the Internet. The same applies to sudo apt install ....
Also, sudo apt purge nvidia* does not help, since I end up at the same screen on boot, and the computer freezes.
