Today I upgraded from 20.04 to 22.04. There were no errors in upgrade process and rebooted.
When I logged into Ubuntu I can insert my password to gnome using my usb-keyboard and mouse pointer also working. But after few seconds both stop working (specially after desktop is loaded)
lsusb shows
Bus 001 Device 003: ID 413c:2113 Dell Computer Corp. KB216 Wired Keyboard
Bus 001 Device 002: ID 413c:250e Dell Computer Corp. Dell Laser Mouse MS3220
In journel logs :
kernel: input: input-remapper mouse as /devices/virtual/input/input34
kernel: input: input-remapper Dell Computer Corp Dell Laser Mouse MS3220 forwarded as /devices/virtual/input/input35
kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
kernel: sd 0:0:0:0: [sda] Stopping disk
kernel: xhci_hcd 0000:05:00.3: WARNING: Host System Error
kernel: hid-generic 0003:413C:2113.0005: usb_submit_urb(ctrl) failed: -19
kernel: Bluetooth: hci0: command 0x0c03 tx timeout
kernel: Bluetooth: hci0: HCI reset during shutdown failed
kernel: xhci_hcd 0000:05:00.4: xHCI host not responding to stop endpoint command.
kernel: xhci_hcd 0000:05:00.4: USBSTS: 0x00000015 HCHalted HSE PCD
kernel: xhci_hcd 0000:05:00.4: xHCI host controller not responding, assume dead
kernel: xhci_hcd 0000:05:00.4: HC died; cleaning up
kernel: usb 3-1: USB disconnect, device number 2
kernel: usb 3-1.1: USB disconnect, device number 4
kernel: usb 3-2: USB disconnect, device number 3
sudo ubuntu-drivers autoinstall - > All the available drivers are already installed.
Here still no proper answer.
nvidia graphic issue is not related to me as I use AMD.
