This is an extension of my earlier question. There I thought tlp was the culprit and stopped the service and it worked. But when I try to run my laptop on battery, again USB devices are not working. Work for few seconds and then stops.
lsusb shows my devices and dmesg
[    1.903341] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=60.60
[    1.903347] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.903350] usb 3-1: Product: USB2.0 Hub
[    1.919601] usb 1-3: New USB device found, idVendor=413c, idProduct=250e, bcdDevice= 1.24
[    1.919608] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.919612] usb 1-3: Product: Dell Laser Mouse MS3220
[    1.919615] usb 1-3: Manufacturer: Dell Computer Corp
[    1.946309] hub 3-1:1.0: USB hub found
[    1.946662] hub 3-1:1.0: 4 ports detected
[    1.959834] input: Dell Computer Corp Dell Laser Mouse MS3220 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3/1-3:1.0/0003:413C:250E.0002/input/input16
[ 50.021872] xhci_hcd 0000:05:00.3: WARNING: Host System Error [ 61.509372] xhci_hcd 0000:05:00.4: xHCI host not responding to stop endpoint command [ 61.509412] xhci_hcd 0000:05:00.4: xHCI host controller not responding, assume dead [ 61.509439] xhci_hcd 0000:05:00.4: HC died; cleaning up [ 61.509462] usb 3-1: USB disconnect, device number 2 [ 61.509467] usb 3-1.1: USB disconnect, device number 4 [ 61.513144] usb 3-1.2: USB disconnect, device number 5 [ 61.518612] usb 3-2: USB disconnect, device number 3
In tlp-stat
Bus 001 Device 002 ID 413c:250e control = on, autosuspend_delay_ms = -1000 -- Dell Computer Corp. Dell Laser Mouse MS3220 (usbhid)
I had tried installing linux-hwe-22.04, stopping tlp , configuring tlp as mentioned here.
I am really frustrated with Ubuntu 22.04.
Sachith Muhandiram
  • 215
  • 20
After long debugging days, I found the solution. It also related to tlp.
In /etc/tlp.conf file.
 Runtime Power Management for PCI(e) bus devices: on=disable, auto=enable.
# Default: on (AC), auto (BAT)
RUNTIME_PM_ON_AC=on RUNTIME_PM_ON_BAT=on
I had to set RUNTIME_PM_ON_BAT=on, it was originally set auto.
Now external usb keyboard and mouse are working without an issue on battery.
Sachith Muhandiram
  • 215
  • 20
