I am using Kubuntu 22.04 LTS on an ASUS Vivobook and i have been experiencing problems with my USB ports.
I tried plugging in my mouse into my computer (on all USB ports) but it wouldn't work. Upon a reboot, i noticed that my mouse would work, but once i logged in it would stop getting power (the mouse sensor would stop). This was on kernel version linux-5.15.0-33-generic.
Running sudo dmesg | grep usb would show similar output:
[   41.505224] usb 3-1: USB disconnect, device number 2
[   41.506124] usb 3-2: USB disconnect, device number 3
[   41.506129] usb 3-2.1: USB disconnect, device number 4
[   41.509860] usb 3-2.2: USB disconnect, device number 5
Needless to say, other commands, such as lsusb wouldn't show the ports or devices.
I tried 5.15.0-30-generic. My USB devices worked again... until the next reboot. I have also tested 5.17.11-051711-generic and 5.10.118-0510118-generic but to no avail.
Out of desperation, i rebooted (once more) and have discovered that my mouse worked until i used my laptop keyboard, so it would seem to me that the keyboard... steals power (?) from the USB ports.
I'm not expecting so much of a solution as i wanted to post to issue somewhere in hopes that if it happens to somebody else they would be able to find a solution here. Thank you in advance for any help provided.
xcell
  • 37
It was tlp. For those who don't know, tlp is a piece of software that helps with reducing battery usage. Apparently, one of the neat things tlp does in that regard is cut power from USB ports. If it affects you, just stick to auto-cpufreq.
Pilot6
  • 92,041
xcell
  • 37
