I have a fresh install of Ubuntu 22.04. The Bang & Olufsen speakers aren't playing sound.
I've gone through https://help.ubuntu.com/stable/ubuntu-help/sound-nosound.html.en but nothing there helps.
I can get sound on headphones, but when I pull the headphones out, the sound is gone, even though the volume is set to max.
Speaker - sof-hda-dsp shows in the settings as being recognized, but it's not being used. When I pull the headphones out, the Output device switches.
sudo lspci -v gives:
00:1f.3 Multimedia audio controller: Intel Corporation Device 51ca (rev 01)
    Subsystem: Hewlett-Packard Company Device 8bdd
    Flags: bus master, fast devsel, latency 32, IRQ 204, IOMMU group 15
    Memory at 601d1d0000 (64-bit, non-prefetchable) [size=16K]
    Memory at 601d000000 (64-bit, non-prefetchable) [size=1M]
    Capabilities: [50] Power Management version 3
    Capabilities: [80] Vendor Specific Information: Len=14 <?>
    Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Kernel driver in use: sof-audio-pci-intel-tgl
    Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
Similarly, I have an older laptop with a nearly identical setup, that actually works:
lspci -v | fgrep -m1 -A19 '00:1f.3'
gives
   00:1f.3 Multimedia audio controller: Intel Corporation Comet Lake PCH-LP cAVS
    Subsystem: Hewlett-Packard Company Comet Lake PCH-LP cAVS
    Flags: bus master, fast devsel, latency 32, IRQ 154
    Memory at b431c000 (64-bit, non-prefetchable) [size=16K]
    Memory at b4000000 (64-bit, non-prefetchable) [size=1M]
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel, snd_sof_pci_intel_cnl
Perhaps switching the kernel driver in use is the key? How can I do that, if it will help?
Sound card not detecting and the command sudo apt-get install build-essential linux-headers-uname -r alsa-base alsa-firmware-loaders alsa-oss alsa-source alsa-tools alsa-tools-gui alsa-utils alsamixergui didn't fix the problem.
How to install Bang and Olufsen Audio drivers for HP laptop? failed to solve my problem.
No sound on headphones with sof-hda-dsp audio on ubuntu (and variants) also failed.
Audio output doesn't switch when headphones connect or disconnect didn't help either.
Ubuntu 20.04 - No sound also failed
cat /proc/asound/cards produces the following output:
 0 [sofhdadsp      ]: sof-hda-dsp - sof-hda-dsp
                      HP-HPEnvyLaptop17_cw0xxx-Type1ProductConfigId-8BDD
sudo gedit /etc/modprobe.d/alsa-base.conf
and add
options snd-hda-intel model=generic
as suggested Ubuntu 20.04 - No sound also failed.
using sof-bin as suggested by Sound card not detected - Ubuntu 20.04 - sof-audio-pci also failed.
I'm also getting
[    0.475866] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[    0.476486] pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
during the boot process. Is this connected to why my speakers don't work?
I have done the standard sudo apt update && sudo apt upgrade to no avail, as well.
when I grep for audio within dmesg:
[    0.116257] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    7.147645] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    7.147677] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[    7.147696] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[    7.148080] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[    8.341717] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    8.407947] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[    8.441644] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[    8.441649] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[    8.441653] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[    8.442691] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[    8.442695] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:21:0
[    8.442697] sof-audio-pci-intel-tgl 0000:00:1f.3: FW ABI is more recent than kernel
[    8.442701] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[    8.538642] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[    8.538647] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:21:0
[    8.538649] sof-audio-pci-intel-tgl 0000:00:1f.3: FW ABI is more recent than kernel
[    8.555720] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:21:0
[    8.555726] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: topology ABI is more recent than kernel
[    8.585014] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC245: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    8.585021] snd_hda_codec_realtek ehdaudio0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    8.585023] snd_hda_codec_realtek ehdaudio0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    8.585025] snd_hda_codec_realtek ehdaudio0D0:    mono: mono_out=0x0
[    8.585026] snd_hda_codec_realtek ehdaudio0D0:    inputs:
[    8.585028] snd_hda_codec_realtek ehdaudio0D0:      Mic=0x19
[    8.634984] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[    8.634992] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
I have also tried adding snd-intel-dspcfg.dsp_driver=1 to /boot/grub/grub.cfg but that changed nothing https://bbs.archlinux.org/viewtopic.php?id=275737
cat /proc/asound/cards gives the output:
sudo aplay -l
gives the output:
card 0: sofhdadsp [sof-hda-dsp], device 0: HDA Analog (*) []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI1 (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 4: HDMI2 (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 5: HDMI3 (*) []
  Subdevices: 1/1
How can I get the sound working on my speakers?
con
  • 338
  • 14
UPDATE
According to this comment, version 6.9 or later of the Linux kernel should fix this. Therefore, whenever possible, try updating your kernel to version 6.9 or later.
It turns out that this a well-known problem with no easy fix, yet. See here for details. The laptop in question in that post is a HP ENVY x360 15-ey0xxx, which also uses Bang & Olufsen speakers. This Q&A post is quite active, with the latest reply as of this writing dated yesterday (July 25th, 2023). I did some digging through it, and it seems that you have two options:
  1. Update your Linux kernel version to 6.3.2 as indicated by this reply. To do so, you can follow the instructions here. However, as explained in these answers, it is not recommended. Therefore, you may want to install a non-LTS version of Ubuntu instead, such as 23.04 or 23.10 when it comes out.
  2. As indicated in this reply, you can install a DKMS module that fixes the problem by following the instructions here. However, for this option, it is extremely important to note the following warning under the reply:
Thanks for the patch, but note that this change can't be taken.
It's dangerous and may burn speakers on other machines that don't use
this configuration.
For now, those info relies on the BIOS ACPI setup with _DSD entry, and vendors should fix it with BIOS updates.
There have been already discussions how to deal with vendors who don't cooperate well.
I think both of these options are not ideal, and I would personally wait until this problem is fixed in a future release of Ubuntu.
Mahmoud
  • 216
you can install Linux kernel 6.8 or 6.9-rc1 disabling Secureboot in the bios and the speakers might start working. using this guide https://itsfoss.com/upgrade-linux-kernel-ubuntu/
Installing Xubuntu 23.1 did not make my speakers make any sound. Installing these newer kernels did.
Edit: on the developer version Xubuntu Noble Numbat with unsigned mainline kernel 6.9-rc1 the laptop speakers work too.
S.A.
