I'm using an Acer Aspire ES1-533 laptop. I already have Ubuntu 18.04 installed and I'm really happy with the OS. Installing 18.04 was a nightmare, but I was able to do it by following this guide https://www.reddit.com/r/linux4noobs/comments/hnke1e/guide_installing_ubuntu_on_acer_aspire_es15/
However trying to install 20.04 or 22.04 has proven to be impossible. I have already tried the recommendations in this thread Problems installing Ubuntu on Acer laptop to no avail. Could you guys help me please? I'm very new to Linux, but Ubuntu 18.04 isn't supported anymore and I'd like to keep using it. Many thanks in advance.
Subscribe to Ubuntu Pro.
It's free, it's supported for five more years, and it bypasses the problem with your locked UEFI.
Of course, you will be using 2018-vintage applications on that 2018-vintage OS. You can sometimes get around that limitation by using Snap-based software.
user535733
  • 68,493
I had the same problem. After some search I managed to solve my problem with the following steps:
  1. Download the iso's for Ubuntu 22.04 and Ubuntu 18.04. Create a bootable pen drive for both.
  2. Boot the 22.04 pen drive and press E on the grub option Try ubuntu without installing.
  3. Add acpi=off nomodeset after /casper/vmlinuz and press F10.
    • Wifi will not work, the touchpad might have a weird behavior and the battery status will not show up, so make sure to plug the charger (after installation these problems won't exist).
  4. On terminal run the command and follow the installation steps:
sudo ubiquity -b
  1. Turn off the computer by pressing the power button and boot the 18.04 live cd.
  2. On terminal, mount the newly installed system on /mnt :
sudo mount /dev/sda2 /mnt
sudo mkdir /mnt/boot/efi
sudo mount /dev/sda1 /mnt/boot/efi
for i in /dev /dev/pts /proc /sys; do sudo mount -B $i /mnt$i; done
  • Where sda2 is the root partition and sda1 is the EFI system partition
  1. Load efivars:
sudo modprobe efivars
  1. Reinstall grub:
sudo apt-get install --reinstall grub-efi-amd64
sudo grub-install --no-nvram --root-directory=/mnt
  1. Change root to /mnt and update grub:
sudo chroot /mnt
update-grub
  1. Remove the package secureboot-db :
apt remove secureboot-db
apt-mark hold secureboot-db
  1. Move and rename the installed bootloader:
cd /boot/efi/EFI
cp -R ubuntu/* BOOT/
cd BOOT
cp grubx64.efi bootx64.efi
  1. Turn off the computer and boot the installed system, then run:
echo "grub-efi-amd64 grub2/force_efi_extra_removable boolean true" | sudo debconf-set-selections
sudo update-grub
  1. Reboot the system.
References:
mattbc
