53
I installed Eclipse, openjdk6 and downloaded and extracted the sdk manager file.
Now, When I created an Android project I got the following error:
2012-06-06 18:44:40 - contactManager] /home/catia/android-sdks/platform-tools/aapt:
error while loading shared libraries: libz.so.1: cannot open shared object file:
No such file or directory
And this one when I tried to create an AVD Manager:
[2012-06-06 19:00:18 - SDK Manager] /home/catia/android-sdks/tools/mksdcard: error
while loading shared libraries: libstdc++.so.6: cannot open shared object file: No
[2012-06-06 19:00:18 - SDK Manager] Failed to create the SD card.
[2012-06-06 19:00:18 - SDK Manager] Failed to create sdcard in the AVD folder.
CJBS
  • 181
csbl
  • 691
8 Answers8
55
If you are using Debian Jessie (or Ubuntu 13.10+), try
sudo apt-get install lib32stdc++6
46
This problem is occurring because the Android SDK is compiled for a 32-bit GNU/Linux system, and your Ubuntu system is a 64-bit GNU/Linux system. The solution should be easy (since Ubuntu fully supports running 32-bit programs on a 64-bit OS)--just install the 32-bit versions of the libraries it needs.
The simplest and easiest way to do this is to install the 32-bit versions of all the most commonly used libraries, by installing the ia32-libs Install ia32-libs package. You can do this in the Software Center or in the Terminal with:
sudo apt-get update
sudo apt-get install ia32-libs
Originally ia32-libs was provided because Ubuntu, in its default configuration, didn't support installing 32-bit Ubuntu packages on a 64-bit system. Now that this is fully supported by default, the ia32-libs package just causes the same 32-bit packages to be installed on your 64-bit system that would be installed on a minimal 32-bit system. (So for anyone who is worried this might not work now that multarch is supported by default: it still works.)
Source: Android/Eclipse Installation on Ubuntu 11.04 - aapt and adb not working properly
See also: Eclipse Android Plugin — libncurses.so.5
Eliah Kagan
  • 119,640
36
This thread was the fix for me.
Specifically, installing this package:
sudo apt-get install lib32z1 lib32z1-dev
ether_joe
  • 1,053
  • 14
16
I just ran into this on Ubuntu 14.04 64-bit. My solution was:
sudo apt-get install -y libc6:i386 libgcc1:i386 libstdc++6:i386 libz1:i386
Based on the shared libraries required for the aapt tool:
$ readelf -d android-sdk-linux/build-tools/20.0.0/aapt | grep -i shared
 0x00000001 (NEEDED)                     Shared library: [librt.so.1]
 0x00000001 (NEEDED)                     Shared library: [libdl.so.2]
 0x00000001 (NEEDED)                     Shared library: [libpthread.so.0]
 0x00000001 (NEEDED)                     Shared library: [libz.so.1]
 0x00000001 (NEEDED)                     Shared library: [libstdc++.so.6]
 0x00000001 (NEEDED)                     Shared library: [libm.so.6]
 0x00000001 (NEEDED)                     Shared library: [libgcc_s.so.1]
 0x00000001 (NEEDED)                     Shared library: [libc.so.6]
bmaupin
  • 5,371
This works for me: aptitude install lib32stdc++6
Eliah Kagan
  • 119,640
This worked for me.
Go to synaptic --> Search for lib32z1 --> select both runtime and development Apply and u r done.
Raj
  • 145
For Ubuntu >= 13.04 instead of ia32-libs you need libgl1-mesa-dev:i386
sudo apt-get install libgl1-mesa-dev:i386
Check Complete Installation Guide for Android SDK / ADT Bundle on Ubuntu
raghavsood33
  • 131
For Ubuntu 15.04, the following was necessary:
sudo apt-get install lib32stdc++6 lib32z1
Six
  • 842
