I have the latest Android SDK installed on Ubuntu 12.04 x64 I am having almost an identical problem as Problems with Eclipse and Android SDK. The Eclipse ADT plugin is not working for me, and its Android window shows
SDK/build-tools/17.0.0/aapt: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
when I create a new Android project.
Then I tried
sudo apt-get install ia32-libs
but the commands fails and returns
 ia32-libs : Depends: ia32-libs-multiarch
Up until now, I followed this answer which worked for the 32-bit adb, and this may have affected how Ubuntu is handling ia-32-libs. What must be done to correctly install the necessary libraries to get all the 32-bit Android tools to run correctly?
update
I tried this answer but it didn't work.
I tried sudo apt-get purge libc6:i386 libncurses5:i386 libstdc++6:i386
but ia32-libs still did't install.
output of ldd ./aapt
linux-gate.so.1 =>  (0xf778f000)
librt.so.1 => /lib32/librt.so.1 (0xf7768000)
libdl.so.2 => /lib32/libdl.so.2 (0xf7760000)
libpthread.so.0 => /lib32/libpthread.so.0 (0xf7740000)
libz.so.1 => not found
libstdc++.so.6 => /usr/lib32/libstdc++.so.6 (0xf7658000)
libm.so.6 => /lib32/libm.so.6 (0xf7628000)
libgcc_s.so.1 => /usr/lib32/libgcc_s.so.1 (0xf7608000)
libc.so.6 => /lib32/libc.so.6 (0xf7460000)
/lib/ld-linux.so.2 (0xf7790000)
libz.so.1 is not found, and Ubuntu says that zlib1g is already most current.
Here's what worked
sudo apt-get install libgl1-mesa-dri:i386
sudo apt-get install ia32-libs-multiarch:i386
5 Answers5
in Ubuntu 13.10 the ia32-libs package is no more present.
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
the second, shall install all its dependencies and resolve the compiling problems. The dependencies are:
gcc-4.8-base:i386 libc6:i386 libdrm-intel1:i386 libdrm-nouveau2:i386
libdrm-radeon1:i386 libdrm2:i386 libelf1:i386 libexpat1:i386 libffi6:i386
libgcc1:i386 libglapi-mesa:i386 libllvm3.3:i386 libpciaccess0:i386
libstdc++6:i386 libtxc-dxtn-s2tc0:i386 zlib1g:i386
Bye,
E.
sudo add-apt-repository ppa:gnome3-team/gnome3
sudo apt-get update
sudo apt-get install libcanberra-gtk-module
I had this same issue. Run these commands
chad
  • 965
Executing the following commands would install ia32-libs multiarch package.
sudo apt-get update
thefourtheye
  • 4,922
  • 26
  • 32
Your solution didn't work for me, what did worked was installing libcupsfilters1:i386 before ia32-libs. as suggested by John in the comment #47 of this bug on launchpad.
But I guess this workaround depends on the i386 libraries installed on the machine so the answer will be user-dependent.
Cheers.
