48
I upgraded to Ubuntu 23.04. Now, when I run a pip command (installed using sudo apt install python3-pip), I get this error:
$ pip install --user <foobar>
error: externally-managed-environment
× This environment is externally managed ╰─> To install Python packages system-wide, try apt install python3-xyz, where xyz is the package you are trying to install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages. hint: See PEP 668 for the detailed specification.
What does this mean? How can I avoid this error?
What if I want to install a package user-wide (--user), not system-wide? How do I do that?
Flimm
  • 44,031
6 Answers6
47
There's a good article on OMGUbuntu about this: 3 Ways to Solve Pip Install Error on Ubuntu 23.04
Here's the summary. There are three ways to approach this problem:
1. Install the Python package using APT
For instance, if you want to install the requests Python library, you can install it using APT instead, like this:
sudo apt install python3-requests
This will install this library system-wide.
Not all packages available on PyPI have been packaged and included in the Debian/Ubuntu repositories, so this method won't work for some packages.
Or: 2. Create a virtual environment using venv or virtualenv
Make sure venv is installed by running:
sudo apt install python3-venv
To create a new virtual environment in a directory named .venv, run:
python3 -m venv .venv
To activate this virtual environment (which modifies the PATH environment variable), run this:
source .venv/bin/activate
Now you can install a library like requests in this virtual environment:
pip install requests
The files will get installed under the .venv/ directory.
If you want to leave the virtual environment, you can run:
deactivate
If you don't want to run source .venv/bin/activate and deactivate, then you can run the executable by prefixing its path, like this:
 $ .venv/bin/pip install requests
 $ .venv/bin/python3
 >>> import request
 >>> help(requests)
Or: 3. Use pipx
pipx lets you install and run Python applications in isolated environments. This is the recommended way to install PyPI packages that represent command-line applications.
To install pipx, run:
 sudo apt install pipx
pipx needs ~/.local/bin/ to be in your PATH. You can automatically modify your shell configuration (such as ~/.bashrc) to modify PATH appropriately by running:
 pipx ensurepath
(You may need to close your terminal application and open it again for the changes to take effect.)
Now you can install a package from PyPI, like this:
 pipx install pycowsay
And you can run the command that you just installed, like this:
$ pycowsay Mooo!
< Mooo! >
\ ^^ \ (oo)_______ ()\ )/
||----w | || ||
As you can see, pipx installed a symlink in ~/.local/bin/ to the executable in a virtual environment:
$ ls -l ~/.local/bin/pycowsay
lrwxrwxrwx 1 flimm flimm 50 May 24 11:19 /home/flimm/.local/bin/pycowsay -> /home/flimm/.local/pipx/venvs/pycowsay/bin/pycowsay*
Or: 4. Pass --break-system-packages flag:
If you want to ignore the warning, you can pass the --break-system-packages flag:
pip install --break-system-packages --user <foobar>
This method is not recommended, because you may find yourself with mysterious broken installations of Python packages months or years later, after you've forgotten that you used --break-system-packages and installed other conflicting Python packages.
Flimm
  • 44,031
10
In a terminal, delete this file with:
sudo rm /usr/lib/python3.11/EXTERNALLY-MANAGED
and everything will be OK!
TommyPeanuts
  • 1,147
Had the same error on my Ubuntu 23.04. I tried pip install {package_name} --break-system-packages It worked for me. Hope it helps. Thank you.
A quick solution to this problem is directly using the python inside the env.
1.- Create the virtual environment: python -m venv <env_name>
2.- Activated it: source <env_name>/bin/activate
3.- Install the package you need: sudo venv/bin/python3 -m pip install <package_name>
This should fix it.
If you've got the venv set up and are still getting the error, make sure the venv folder has the correct permissions. I spent a long time spinning my wheels before I chown'd the folder to my username. Then do not use sudo.
Check folder owner:
  1. Go to the parent folder
  2. List the folder's owner with:
     ls -Al
  3. If the folder is owned by root in group root:
     chown -R username:username ./venvfolder/
-1
I had created the conda virtual environment, and facing the same issue with pip , so conda install kafka-python worked for me
Raj
