How did that happen? Many miss names and modules.
pip install pykaldi
error: externally-managed-environment
× This environment is externally managed ╰─> To install Python packages system-wide, try apt install python3-xyz, where xyz is the package you are trying to install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.12/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages. hint: See PEP 668 for the detailed specification.
sudo apt-get install python3-xyz Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package python3-xyz
Ajay
  • 2,241
sudo apt-get install python3-xyz failed because xyz is a placeholder. Replace it with the actual package name, like python3-lxml
Fer
