while I'm installing a specific tool related to pentesting I encountered following problem in my ubuntu terminal it showing This environment is externally managed ╰─> To install Python packages system-wide, try apt install python3-xyz, where xyz is the package you are trying to install.
not only this time this happened each and everytime when I was trying to install python packaged tools I'm encountering this problem. somepne please look into these issue.
                   This APT has Super Cow Powers.
david@david:~/Desktop$ git clone https://github.com/guelfoweb/knock.git
Cloning into 'knock'...
remote: Enumerating objects: 1615, done.
remote: Counting objects: 100% (179/179), done.
remote: Compressing objects: 100% (94/94), done.
remote: Total 1615 (delta 93), reused 136 (delta 76), pack-reused 1436 (from 1)
Receiving objects: 100% (1615/1615), 542.32 KiB | 122.00 KiB/s, done.
Resolving deltas: 100% (744/744), done.
david@david:~/Desktop$ cd knock
david@david:~/Desktop/knock$ pip install .
error: externally-managed-environment
× This environment is externally managed ╰─> To install Python packages system-wide, try apt install python3-xyz, where xyz is the package you are trying to install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.12/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages. hint: See PEP 668 for the detailed specification. david@david:~/Desktop/knock$
