I've gone through the process of installing WSL2 on a Windows 11 laptop and can successfully run, for example, GUI-type LibreOffice apps from the Terminal command line.
So far, so good.
Now I would like to try using Gnome.
I've installed Gnome desktop using:
sudo tasksel install ubuntu-desktop
... but after rebooting I get messages such as:
<3>WSL (1408) ERROR: UtilTranslatePathList:2671: Failed to translate C:\WINDOWS\system32
NotTheDr01ds
  • 22,082
Dabbo
  • 151
WSL is not made to run a full Linux Desktop environment, but it can run single graphical applications in a single window.
If you are looking for installing and running a complete Ubuntu desktop on Windows with minimal effort, take a look at Multipass from Canonical and add a Desktop enviroment to the base installation.
noisefloor
  • 1,769
The error that you mention seems unrelated to you trying to run Ubuntu Desktop under WSL.
That error is typically caused by a combination of:
  • Upgrading to a recent release of WSL
  • A directory that doesn't exist being in your Windows path.
In Ubuntu:
powershell.exe -c '$env:PATH' | tr ';' '\n'
  • Look for a directory in that list that doesn't exist in Windows.
  • Go to the Edit the system environment variables Windows setting
  • Press the Environment Variables button
Remove the bad directory from the PATH variable. This might be under either your user or the System variable list.
And while I don't necessarily recommend it, for information on running Ubuntu Desktop in Ubuntu on WSL, see the following questions:
NotTheDr01ds
  • 22,082
