29
My Ubuntu (20.04) Software is prompting a new firmware available: UEFI dbx 77--> 217 (?), but when I try to update I receive the following error message:
Impossible to update UEFI dbx.
Blocked executable in the ESP, ensure grub and shim are up to date:/boot/efi/EFI/Boot/shimx64.efi Authenticode checksum [_checksum code_] is presente in dbx.
I am not really sure what this implies and, if I understood it correctly, why is it jumping from version 77 to 217. A bit more of details on the system:
$ lscpu
Architecture:                    x86_64
CPU op-mode(s):                  32-bit, 64-bit
Byte Order:                      Little Endian
Address sizes:                   39 bits physical, 48 bits virtual
CPU(s):                          12
On-line CPU(s) list:             0-11
Thread(s) per core:              2
Core(s) per socket:              6
Socket(s):                       1
NUMA node(s):                    1
Vendor ID:                       GenuineIntel
CPU family:                      6
Model:                           165
Model name:                      Intel(R) Core(TM) i7-10850H CPU @ 2.70GHz
Samveen
  • 288
Py-ser
  • 687
6 Answers6
24
I had a similar problem on my Dell 5820 under Ubuntu 22.04. I suggest checking whether the binary is used.
To do this I suggest to check whether the file /boot/efi/EFI/Boot/shimx64.efi is listed in the boot entries:
efibootmgr -v
In my case it was not but the more recent (note the slight difference in path) /boot/efi/EFI/ubuntu/shimx64.efi was used.
I then noticed that /boot/efi/EFI/Boot/shimx64.efi was years older than the other files in /boot/efi/EFI/Boot/:
sudo ls -lah /boot/efi/EFI/Boot/
I then removed it and the upgrade worked smoothly:
sudo rm /boot/efi/EFI/Boot/shimx64.efi
sudo fwupdmgr update
Benoit
  • 391
Your Ubuntu Linux 20.04 LTS contains grub2 and other booting software in older versions, which are blacklisted in DBX version 217 due to security issues. Updating the DBX database in flash of your PC would result in your system to be excluded from booting for future (in UEFI secure-boot mode). This cannot be reverted!
Not a good idea to update to DBX version 217 unless you have updated e. g. to Ubuntu 22.04 LTS with a grub2 etc. which is not excluded from booting in DBX. fwupdmgr checks compatibility for you and then therefore denies to update the DBX to a version which would make your PC system inoperable.
Recommendations:
  1. Do not update and live with security risks
  2. Update Ubuntu to a current version like 22.04 LTS or 22.10 and then do the update to DBX version 217. This should work and minimize security risks.
Note: It would be nonsense to update to DBX version 217 and then boot your system with secure-boot disabled in UEFI-BIOS from that time. Then you would have to live with more security risks. This would arise further risks to other OS too. Return to 1) or 2).
Please be aware, that recommendation 2) will possibly exclude several other of your existing boot media like USB memory sticks and CDs etc. from booting in future. So make sure, you really want 2) or live some time with 1) until you are ready for 2).
zx485
  • 2,865
ansa
  • 61
See: https://github.com/fwupd/fwupd/issues/5035 TL;DR Upgrade to the newest version of fwupd
Anonymous
  • 19
I was having the same issue. I just moved all of the offending files reported by the upgrade into a safe place outside of the boot folder. One you ensure everything works correctly, you can delete the files you moved.
In your case it would be something like this:
$ sudo mv /boot/efi/EFI/Boot/shimx64.efi ~/Documents
$ sudo fwupdmgr update
If you get another error after running fwupdmgr move the file it complains about to your Documents folder. I had to move 3 "Blocked Executable" files before the update utility worked. Once the update succeeds, make sure grub is up to date:
$ sudo update-grub
Now you can reboot and everything should work as normal. You can delete the efi folders quarantined in your Documents folder.
In my case moving the files fwupdmgr lists out of the /boot folder worked. I have moved from Ubuntu 20.04 to 22.04 some weeks ago and got this update of DBX listed.
In my case there were a lot of old files in the /boot/efi/boot-repair/log folder so I moved the whole log folder out of /boot area. Then "sudo fwupdmgr update" worked and I did "sudo update-grub" without rebooting. I guess this is the main thing: Do not reboot before you have done "sudo update-grub"
Then I rebooted and my holy machine comes to life again.
frank
He said it is fixed: Fixed in Fixed in https://gitlab.com/fwupd/lvfs-website/-/merge_requests/1363 for future firmwares. Probably it is a save although annoying thing to ignore update request until Ubuntu fixed it.
Gri Ma
  • 129
