I have an laptop running 20.04 (no secure-boot, title it old). I wanted to move the boot disk to a new laptop (titled new) which has secure-boot enabled. I do not want to disable secure boot on new, because I have windows installed on new with requirements to keep secure boot enabled.
To test whether this was possible for new, I plugged my original install live-media (the xubuntu 18.04 live boot image from 2019 on USB, used to install old), and tried to boot new off it. This succeeded perfectly.
Next I took the boot disk from old, plugged it into new, selected the disk as boot media, and got to the grub console. This is where I got stuck with the following error message:
Loading Linux 5.4.0-70-generic ...
error: bad shim signature.
Loading initial ramdisk ...
error: you need to load the kernel first.
Press any key to continue...
I booted old to compare the kernel on the boot media vs the kernel on disk:
samveen@samveen-X230:~$ sudo sbverify --list /media/temp/casper/vmlinuz
signature 1
image signature issuers:
- /C=GB/ST=Isle of Man/L=Douglas/O=Canonical Ltd./CN=Canonical Ltd. Master Certificate Authority
image signature certificates:
- subject: /C=GB/ST=Isle of Man/O=Canonical Ltd./OU=Secure Boot/CN=Canonical Ltd. Secure Boot Signing
issuer: /C=GB/ST=Isle of Man/L=Douglas/O=Canonical Ltd./CN=Canonical Ltd. Master Certificate Authority
samveen@samveen-X230:/media/temp/casper$ sudo sbverify --list /boot/vmlinuz-5.4.0-70-generic
signature 1
- subject: /C=GB/ST=Isle of Man/O=Canonical Ltd./OU=Secure Boot/CN=Canonical Ltd. Secure Boot Signing (2017)
Both are signed and valid, so I checked on the bootloader chain (shim and grub):
samveen@samveen-X230:~$ sudo sbverify --list /boot/efi/EFI/ubuntu/shimx64.efi
warning: data remaining[834920 vs 960472]: gaps between PE/COFF sections?
signature 1
- /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Corporation UEFI CA 2011
- subject: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Windows UEFI Driver Publisher
issuer: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Corporation UEFI CA 2011
- subject: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Corporation UEFI CA 2011
issuer: /C=US/ST=Washington/L=Redmond/O=Microsoft Corporation/CN=Microsoft Corporation Third Party Marketplace Root
samveen@samveen-X230:~$ sudo sbverify --list /boot/efi/EFI/ubuntu/grubx64.efi
signature 1
- subject: /C=GB/ST=Isle of Man/O=Canonical Ltd./OU=Secure Boot/CN=Canonical Ltd. Secure Boot Signing (2022 v1)
samveen@samveen-X230:~$ sudo sbverify --list /boot/efi/EFI/ubuntu/mmx64.efi
warning: data remaining[742792 vs 860824]: gaps between PE/COFF sections?
signature 1
That's all valid, with the Canonical Ltd. Master CA being able to validate everything.
What am I missing here which is causing the failure to boot?
