I've been using Ubuntu 20.04 on my machine for a while now, and I've had the issue with no Wi-Fi Adapter before.
However, my go-to-fix (which is described here: Ubuntu 20.04 - No WiFi adapter found) no longer works.
It seems like this is a new bug, since the error messages are different. My error code from dmesg | grep iwlwifi (see below for full log) shows an error code of -5; whereas my previous issue had an error code of 110.
Any one got any ideas on how to solve this?
My system:
uname -a
Linux xxx 5.13.0-27-generic #29~20.04.1-Ubuntu SMP Fri Jan 14 00:32:30 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
My HW:
sudo lshw -class network
*-network
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:93:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:17 memory:b7200000-b7203fff
*-network
description: Ethernet interface
product: Ethernet Connection (14) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 11
serial: 38:14:28:4f:b9:25
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.13.0-27-generic duplex=full firmware=0.4-4 ip=10.93.100.122 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:170 memory:b7480000-b749ffff
My error logs:
[ 18.293630] iwlwifi: unknown parameter 'd0i3_disable' ignored
[ 18.293633] iwlwifi: unknown parameter 'lar_disable' ignored
[ 18.293978] iwlwifi 0000:93:00.0: enabling device (0000 -> 0002)
[ 18.322181] iwlwifi 0000:93:00.0: api flags index 2 larger than supported by driver
[ 18.322227] iwlwifi 0000:93:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.25
[ 18.323547] iwlwifi 0000:93:00.0: loaded firmware version 63.c04f3485.0 ty-a0-gf-a0-63.ucode op_mode iwlmvm
[ 18.353126] iwlwifi 0000:93:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 18.514384] iwlwifi 0000:93:00.0: Microcode SW error detected. Restarting 0x0.
[ 18.514487] iwlwifi 0000:93:00.0: Start IWL Error Log Dump:
[ 18.514488] iwlwifi 0000:93:00.0: Status: 0x00000040, count: 6
[ 18.514489] iwlwifi 0000:93:00.0: Loaded firmware version: 63.c04f3485.0 ty-a0-gf-a0-63.ucode
[ 18.514491] iwlwifi 0000:93:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 18.514492] iwlwifi 0000:93:00.0: 0x002002F0 | trm_hw_status0
[ 18.514493] iwlwifi 0000:93:00.0: 0x00000000 | trm_hw_status1
[ 18.514494] iwlwifi 0000:93:00.0: 0x004DA004 | branchlink2
[ 18.514495] iwlwifi 0000:93:00.0: 0x004D07EA | interruptlink1
[ 18.514495] iwlwifi 0000:93:00.0: 0x004D07EA | interruptlink2
[ 18.514496] iwlwifi 0000:93:00.0: 0x004D8DEA | data1
[ 18.514497] iwlwifi 0000:93:00.0: 0x00000010 | data2
[ 18.514498] iwlwifi 0000:93:00.0: 0x00000000 | data3
[ 18.514499] iwlwifi 0000:93:00.0: 0x00000000 | beacon time
[ 18.514500] iwlwifi 0000:93:00.0: 0x00012961 | tsf low
[ 18.514501] iwlwifi 0000:93:00.0: 0x00000000 | tsf hi
[ 18.514502] iwlwifi 0000:93:00.0: 0x00000000 | time gp1
[ 18.514502] iwlwifi 0000:93:00.0: 0x00024AAB | time gp2
[ 18.514503] iwlwifi 0000:93:00.0: 0x00000001 | uCode revision type
[ 18.514504] iwlwifi 0000:93:00.0: 0x0000003F | uCode version major
[ 18.514505] iwlwifi 0000:93:00.0: 0xC04F3485 | uCode version minor
[ 18.514506] iwlwifi 0000:93:00.0: 0x00000420 | hw version
[ 18.514507] iwlwifi 0000:93:00.0: 0x18489002 | board version
[ 18.514507] iwlwifi 0000:93:00.0: 0x8008FF00 | hcmd
[ 18.514508] iwlwifi 0000:93:00.0: 0x00020000 | isr0
[ 18.514509] iwlwifi 0000:93:00.0: 0x60000000 | isr1
[ 18.514510] iwlwifi 0000:93:00.0: 0x58F00002 | isr2
[ 18.514510] iwlwifi 0000:93:00.0: 0x00C0000C | isr3
[ 18.514511] iwlwifi 0000:93:00.0: 0x00000000 | isr4
[ 18.514512] iwlwifi 0000:93:00.0: 0x00000000 | last cmd Id
[ 18.514513] iwlwifi 0000:93:00.0: 0x004D8DEA | wait_event
[ 18.514514] iwlwifi 0000:93:00.0: 0x00000000 | l2p_control
[ 18.514514] iwlwifi 0000:93:00.0: 0x00000000 | l2p_duration
[ 18.514515] iwlwifi 0000:93:00.0: 0x00000000 | l2p_mhvalid
[ 18.514516] iwlwifi 0000:93:00.0: 0x00000000 | l2p_addr_match
[ 18.514517] iwlwifi 0000:93:00.0: 0x00000009 | lmpm_pmg_sel
[ 18.514518] iwlwifi 0000:93:00.0: 0x00000000 | timestamp
[ 18.514518] iwlwifi 0000:93:00.0: 0x00000024 | flow_handler
[ 18.514591] iwlwifi 0000:93:00.0: Start IWL Error Log Dump:
[ 18.514592] iwlwifi 0000:93:00.0: Status: 0x00000040, count: 7
[ 18.514593] iwlwifi 0000:93:00.0: 0x2010070D | ADVANCED_SYSASSERT
[ 18.514594] iwlwifi 0000:93:00.0: 0x00000000 | umac branchlink1
[ 18.514595] iwlwifi 0000:93:00.0: 0x8045CF40 | umac branchlink2
[ 18.514596] iwlwifi 0000:93:00.0: 0x0108E0B2 | umac interruptlink1
[ 18.514597] iwlwifi 0000:93:00.0: 0x00000000 | umac interruptlink2
[ 18.514597] iwlwifi 0000:93:00.0: 0x00000005 | umac data1
[ 18.514598] iwlwifi 0000:93:00.0: 0xDEADBEEF | umac data2
[ 18.514599] iwlwifi 0000:93:00.0: 0xDEADBEEF | umac data3
[ 18.514600] iwlwifi 0000:93:00.0: 0x0000003F | umac major
[ 18.514601] iwlwifi 0000:93:00.0: 0xC04F3485 | umac minor
[ 18.514601] iwlwifi 0000:93:00.0: 0x00024AA4 | frame pointer
[ 18.514602] iwlwifi 0000:93:00.0: 0xC0885E90 | stack pointer
[ 18.514603] iwlwifi 0000:93:00.0: 0x00010C00 | last host cmd
[ 18.514604] iwlwifi 0000:93:00.0: 0x00000000 | isr status reg
[ 18.514659] iwlwifi 0000:93:00.0: IML/ROM dump:
[ 18.514660] iwlwifi 0000:93:00.0: 0x00000B03 | IML/ROM error/state
[ 18.514671] iwlwifi 0000:93:00.0: 0x00007837 | IML/ROM data1
[ 18.514681] iwlwifi 0000:93:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 18.514688] iwlwifi 0000:93:00.0: Fseq Registers:
[ 18.514691] iwlwifi 0000:93:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 18.514698] iwlwifi 0000:93:00.0: 0x80440002 | FSEQ_TOP_INIT_VERSION
[ 18.514705] iwlwifi 0000:93:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 18.514712] iwlwifi 0000:93:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 18.514718] iwlwifi 0000:93:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 18.514725] iwlwifi 0000:93:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 18.514729] iwlwifi 0000:93:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 18.514735] iwlwifi 0000:93:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 18.514739] iwlwifi 0000:93:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 18.514745] iwlwifi 0000:93:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 18.514751] iwlwifi 0000:93:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 18.514758] iwlwifi 0000:93:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 18.514768] iwlwifi 0000:93:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 19.435227] iwlwifi 0000:93:00.0: Failed to run INIT ucode: -5
