I am on Kubuntu 22.04 and have installed wine64 the usual way using apt:
$ wine --version
it looks like wine32 is missing, you should install it.
as root, please execute "apt-get install wine32"
wine-6.0.3 (Ubuntu 6.0.3~repack-1)
$ wine64 --version
When I try to install wine32 using "apt-get install wine32", I get:
$ sudo apt install wine32
[sudo] password for oreo:
Reading package lists... Done
Building dependency tree... Done
apt : Depends: libapt-pkg6.0 (>= 2.4.5) but it is not going to be installed
Depends: libsystemd0 but it is not installable
bsdutils : PreDepends: libsystemd0 but it is not installable
init : PreDepends: systemd-sysv
shim-signed : Depends: grub-efi-amd64-signed but it is not going to be installed or
grub-efi-arm64-signed but it is not installable
Depends: grub2-common (>= 2.04-1ubuntu24)
util-linux : PreDepends: libsystemd0 but it is not installable
PreDepends: libudev1 (>= 183) but it is not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
This is impossible to fix and I can't figure out which is the offending package that I must downgrade (others who have faced this issue had to downgrade some packages).
Any help is much appreciated.
