I'm trying to install wine, but when it says I need wine32, I can't install it either with similar messages as trying to install i386 dependencies.
I read a post (Cannot install wine32 in Jammy (22.04)) where he narrowed it down to libsystemd0
from dpkg-architecture -l:
DEB_BUILD_ARCH=amd64
DEB_BUILD_ARCH_ABI=base
DEB_BUILD_ARCH_BITS=64
DEB_BUILD_ARCH_CPU=amd64
DEB_BUILD_ARCH_ENDIAN=little
DEB_BUILD_ARCH_LIBC=gnu
DEB_BUILD_ARCH_OS=linux
DEB_BUILD_GNU_CPU=x86_64
DEB_BUILD_GNU_SYSTEM=linux-gnu
DEB_BUILD_GNU_TYPE=x86_64-linux-gnu
DEB_BUILD_MULTIARCH=x86_64-linux-gnu
DEB_HOST_ARCH=amd64
DEB_HOST_ARCH_ABI=base
DEB_HOST_ARCH_BITS=64
DEB_HOST_ARCH_CPU=amd64
DEB_HOST_ARCH_ENDIAN=little
DEB_HOST_ARCH_LIBC=gnu
DEB_HOST_ARCH_OS=linux
DEB_HOST_GNU_CPU=x86_64
DEB_HOST_GNU_SYSTEM=linux-gnu
DEB_HOST_GNU_TYPE=x86_64-linux-gnu
DEB_HOST_MULTIARCH=x86_64-linux-gnu
DEB_TARGET_ARCH=amd64
DEB_TARGET_ARCH_ABI=base
DEB_TARGET_ARCH_BITS=64
DEB_TARGET_ARCH_CPU=amd64
DEB_TARGET_ARCH_ENDIAN=little
DEB_TARGET_ARCH_LIBC=gnu
DEB_TARGET_ARCH_OS=linux
DEB_TARGET_GNU_CPU=x86_64
DEB_TARGET_GNU_SYSTEM=linux-gnu
DEB_TARGET_GNU_TYPE=x86_64-linux-gnu
DEB_TARGET_MULTIARCH=x86_64-linux-gnu
I've added the architecture: dpkg --add-architecture i386
It shows up here: dpkg --print-foreign-architectures i386
but I can't install it:
apt-cache policy libsystemd0:{amd64,i386}
libsystemd0:
  Installed: 249.11-0ubuntu3.4
  Candidate: 249.11-0ubuntu3.4
  Version table:
 *** 249.11-0ubuntu3.4 100
        100 /var/lib/dpkg/status
     249.11-0ubuntu3 500
        500 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
libsystemd0:i386:
  Installed: (none)
  Version table:
     249.11-0ubuntu3 500
        500 http://us.archive.ubuntu.com/ubuntu jammy/main i386 Packages
apt install libsystemd0:i386
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: apt : Depends: adduser but it is not going to be installed Depends: gpgv or gpgv2 but it is not going to be installed or gpgv1 but it is not going to be installed Depends: libapt-pkg6.0 (>= 2.4.6) but it is not going to be installed Depends: libc6 (>= 2.34) but it is not installable Depends: libgcc-s1 (>= 3.3.1) but it is not going to be installed Depends: libgnutls30 (>= 3.7.0) but it is not going to be installed Depends: libseccomp2 (>= 2.4.2) but it is not going to be installed Depends: libstdc++6 (>= 11) but it is not going to be installed Depends: libsystemd0 but it is not installable Recommends: ca-certificates but it is not going to be installed
Edit: for the record, following the instructions here: https://www.linuxcapable.com/how-to-install-winehq-on-ubuntu-22-04-lts/
sudo apt install software-properties-common apt-transport-https wget -y
wget -O- https://dl.winehq.org/wine-builds/winehq.key | sudo gpg --dearmor | sudo tee /usr/share/keyrings/winehq.gpg
echo deb [signed-by=/usr/share/keyrings/winehq.gpg] http://dl.winehq.org/wine-builds/ubuntu/ $(lsb_release -cs) main | sudo tee /etc/apt/sources.list.d/winehq.list
All of those commands complete without errors. Then
root@michalk-desktop:~# apt update
Hit:1 http://us.archive.ubuntu.com/ubuntu jammy InRelease
Get:2 http://dl.winehq.org/wine-builds/ubuntu jammy InRelease [8,041 B]
Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
Get:4 http://dl.winehq.org/wine-builds/ubuntu jammy/main amd64 Packages [35.1 kB]
Get:5 http://dl.winehq.org/wine-builds/ubuntu jammy/main all Packages [928 B]
Get:6 http://dl.winehq.org/wine-builds/ubuntu jammy/main i386 Packages [34.9 kB]
Hit:7 https://download.virtualbox.org/virtualbox/debian jammy InRelease
Hit:8 https://ppa.launchpadcontent.net/savoury1/chromium/ubuntu jammy InRelease
Hit:9 https://ppa.launchpadcontent.net/savoury1/ffmpeg4/ubuntu jammy InRelease
Fetched 79.0 kB in 2s (35.1 kB/s)
All packages are up to date.
root@michalk-desktop:~# sudo apt install winehq-stable --install-recommends  -y
E: Unable to locate package winehq-stable
So, trying staging:
root@michalk-desktop:~# sudo apt install winehq-staging --install-recommends  -y
The following packages have unmet dependencies: winehq-staging : Depends: wine-staging (= 7.14~jammy-1) E: Unable to correct problems, you have held broken packages.
root@michalk-desktop:~# sudo apt install wine-staging --install-recommends -y Reading package lists... Done Building dependency tree... Done Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: apt : Depends: libapt-pkg6.0 (>= 2.4.6) but it is not going to be installed Depends: libsystemd0 but it is not installable bsdutils : PreDepends: libsystemd0 but it is not installable init : PreDepends: systemd-sysv libasound2:i386 : Depends: libc6:i386 (>= 2.34) but it is not installable libasound2-plugins:i386 : Depends: libc6:i386 (>= 2.34) but it is not installable Depends: libjack-jackd2-0:i386 (>= 1.9.10+20150825) but it is not installable or libjack-0.125:i386 Depends: libpulse0:i386 (>= 0.99.1-1~) but it is not installable
and so forth.
Edit:
sudo apt install --reinstall libsystemd0=249.11-0ubuntu3
The following packages have unmet dependencies: init : PreDepends: systemd-sysv E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
This machine is a fresh install, about one week old. The only 20.04 remnants is my home directory. I don't pin packages, or rarely install packages with dpkg -i to prevent dependency hell. I don't think I have broken packages, I think this is what it thinks is an "impossible situation". It may be easier for me to do a reinstall of the OS.
Edit: more information.
dpkg -l | egrep -v '^ii|rc'
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
grep -r deb /etc/apt/sources.list /etc/apt/sources.list.d/
/etc/apt/sources.list:deb [arch=amd64 signed-by=/usr/share/keyrings/oracle-virtualbox-2016.gpg] https://download.virtualbox.org/virtualbox/debian jammy contrib
/etc/apt/sources.list:# deb cdrom:[Ubuntu 22.04 LTS _Jammy Jellyfish_ - Release amd64 (20220419)]/ jammy main restricted
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ jammy universe
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy universe
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
/etc/apt/sources.list:deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu jammy-security main restricted
/etc/apt/sources.list:# deb-src http://security.ubuntu.com/ubuntu jammy-security main restricted
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu jammy-security universe
/etc/apt/sources.list:# deb-src http://security.ubuntu.com/ubuntu jammy-security universe
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu jammy-security multiverse
/etc/apt/sources.list:# deb-src http://security.ubuntu.com/ubuntu jammy-security multiverse
/etc/apt/sources.list:# (e.g. netinst, live or single CD). The matching "deb cdrom"
/etc/apt/sources.list.d/savoury1-ubuntu-ffmpeg4-jammy.list:deb https://ppa.launchpadcontent.net/savoury1/ffmpeg4/ubuntu/ jammy main
/etc/apt/sources.list.d/savoury1-ubuntu-ffmpeg4-jammy.list:# deb-src https://ppa.launchpadcontent.net/savoury1/ffmpeg4/ubuntu/ jammy main
/etc/apt/sources.list.d/savoury1-ubuntu-chromium-jammy.list:deb https://ppa.launchpadcontent.net/savoury1/chromium/ubuntu/ jammy main
/etc/apt/sources.list.d/savoury1-ubuntu-chromium-jammy.list:# deb-src https://ppa.launchpadcontent.net/savoury1/chromium/ubuntu/ jammy main
/etc/apt/sources.list.d/savoury1-ubuntu-chromium-jammy.list.save:deb https://ppa.launchpadcontent.net/savoury1/chromium/ubuntu/ jammy main
/etc/apt/sources.list.d/savoury1-ubuntu-chromium-jammy.list.save:# deb-src https://ppa.launchpadcontent.net/savoury1/chromium/ubuntu/ jammy main
/etc/apt/sources.list.d/owncloud.list:deb https://download.owncloud.com/desktop/ownCloud/stable/2.10/linux/Ubuntu_22.04/ /
/etc/apt/sources.list.d/savoury1-ubuntu-ffmpeg4-jammy.list.save:deb https://ppa.launchpadcontent.net/savoury1/ffmpeg4/ubuntu/ jammy main
/etc/apt/sources.list.d/savoury1-ubuntu-ffmpeg4-jammy.list.save:# deb-src https://ppa.launchpadcontent.net/savoury1/ffmpeg4/ubuntu/ jammy main
Edit: more info root@michalk-desktop:~# apt-show-versions | fgrep avail root@michalk-desktop:~# apt-show-versions doesn't have anything with "avail"
karel
  • 122,292
  • 133
  • 301
  • 332
The versions from 64-bit packages and 32-bit have to match.
libsystemd0:
  Installed: 249.11-0ubuntu3.4  #here to high version
  Version table:
     249.11-0ubuntu3 500
libsystemd0:i386:
  Installed: (none)
  Version table:
     249.11-0ubuntu3 500
Then try again please.
nobody
  • 5,792
