I installed wine64 using sudo apt-get install wine64 and when I run wine --version it sends in the terminal that I need wine32 because it's missing. I do sudo apt-get install wine32 as the message suggests and it sends this error message:
Reading package lists... Done
Building dependency tree... Done
apt : Depends: adduser but it is not going to be installed
coreutils : PreDepends: libselinux1 (>= 3.1~) but it is not going to be installed
dpkg : PreDepends: libselinux1 (>= 3.1~) but it is not going to be installed
findutils : PreDepends: libselinux1 (>= 3.1~) but it is not going to be installed
grep : PreDepends: libpcre3 but it is not installable
init : PreDepends: systemd-sysv
login : PreDepends: libpam-runtime but it is not going to be installed
PreDepends: libpam-modules but it is not going to be installed
sed : PreDepends: libselinux1 (>= 3.1~) but it is not going to be installed
shim-signed : Depends: grub-efi-amd64-signed but it is not going to be installed or
grub-efi-arm64-signed but it is not installable
Depends: grub2-common (>= 2.04-1ubuntu24)
tar : PreDepends: libselinux1 (>= 3.1~) but it is not going to be installed
util-linux : PreDepends: libmount1 (>= 2.37.2) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held
packages.
How can I fix this? (using version 22.04.)
