14
I am currently on ubuntu 22.04 LTS release which comes with kernel version 5.15.0-27-generic. I want to downgrade to kernel version 5.13 because of touchpad problem in my lenovo thinkbook.
Is it possible to downgrade the baked in kernel in 22.04 LTS release? If yes, how do I achieve it?
You can try below actions to use pimlie / ubuntu-mainline-kernel.sh:
wget https://raw.githubusercontent.com/pimlie/ubuntu-mainline-kernel.sh/master/ubuntu-mainline-kernel.sh
chmod +x ubuntu-mainline-kernel.sh
search and find your wanted version
ubuntu-mainline-kernel.sh -r | grep 5.13
install that version kernel
ubuntu-mainline-kernel.sh -i v5.13.19
get all menuentries
grep 'menuentry |submenu ' /boot/grub/grub.cfg | cut -f2 -d "'"
change the grub configuration
vi /etc/default/grub from: GRUB_DEFAULT=0 to: GRUB_DEFAULT="Advanced options for Ubuntu>Ubuntu, with Linux 5.13.19-051319-generic"
update grub
update-grub
reboot
reboot now
verify
uname -r
I have updated this answer by @xiaojueguan.
Changes in comparison with that answer:
  • add a variable to define the kernel version to use;
  • use curl instead of wget;
  • get the oldest kernel version Grub entry name programmatically;
  • update the Grub config programmatically;
  • disable upgrading the Linux kernel packages.
# Choose kernel version to install
kernel_version='6.5.0'
Install the old kernel
curl -sL https://raw.githubusercontent.com/pimlie/ubuntu-mainline-kernel.sh/master/ubuntu-mainline-kernel.sh | bash -s -- -i "v$kernel_version"
Get the Grub entry name
Note: Do verify the value of grub_entry_name. The following command gets
the oldest kernel version Grub entry name that is not a recovery mode.
Example value: Ubuntu, with Linux 6.5.0-45-generic
grub_entry_name="$(grep -Po "menuentry '\KUbuntu, [^(']+" /boot/grub/grub.cfg | sort -V | head -1)"
Update grub
sed -i "s/^\sGRUB_DEFAULT=.$/GRUB_DEFAULT='Advanced options for Ubuntu>$grub_entry_name'/" /etc/default/grub update-grub
Disable the kernel package upgrade
apt-mark hold $(dpkg --get-selections | grep -Po "^linux[^\t]+${grub_entry_name##* }")
Reboot system
reboot
Check the currently booted Linux kernel version
uname -r
In my case, after clean install of lubuntu-22 on Dell-Inspiron_5570, experienced "elantech touchpad problem" due to which "two finger scrolling" was not working. After 4-5 hectic days on the work dealing with the arrow keys on keyboard, I found it as kernel incompatibility. Then, tried installing different kernel versions following @xiaojueguan answer and found the version 5.15.0-58-generic to be working for me.
