35
I tried installing beanstalkd with sudo apt-get install beanstalkd (also with -f option) and I get the following error:
Reading package lists... Done
Building dependency tree
You might want to run `apt-get -f install' to correct these:
  beanstalkd: Depends: libevent-1.4-2 (>= 1.4.13-stable) but it is not going to be installed
  mysql-server-5.1: Depends: mysql-client-5.1 (>= 5.1.62-0ubuntu0.10.04.1) but it is not going to be installed
                    Depends: libmysqlclient16 (>= 5.1.21-1) but it is not going to be installed
                    Depends: mysql-server-core-5.1 (>= 5.1.62-0ubuntu0.10.04.1) but it is not going to be installed
                    PreDepends: mysql-common (>= 5.1.62-0ubuntu0.10.04.1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Zanna
  • 72,312
First download the deb package from repository:
apt-get download <package_name>
Install the deb file (it should be in the current folder):
sudo dpkg -i <downloaded_package_deb_file>
Zanna
  • 72,312
ineicu
  • 471
Try
sudo apt-get install -f
with no package in terminal.
If this still gives the error of the dependencies then you will have to issue
sudo apt-get remove beanstalkd
then try
sudo apt-get install mysql-server beanstalkd
That should install the mysql dependencies and beanstalk.
try running sudo apt-get --fix-missing install
fossfreedom
  • 174,526
user95688
  • 39
Run
apt --fix-broken install
with no packages. And the try to install the packages again.
