I'm trying to install CUDA and NVIDIA drivers to use a GeForce 1080 and a Titan XP GPU on my workstation.
However, running:
sudo apt-get install nvidia-driver-440
I got the following error, which I don't know how to solve:
 Reading package lists...  Done
 Building dependency tree
 requested an impossible
 situation or if you are using the unstable  distribution that some
 required packages have not yet been created or been moved out of
 Incoming.  The following information may help to resolve the
 situation:
 nvidia-driver-440 : Depends: libnvidia-gl-440 (=
 440.59-0ubuntu0.18.04.1) but
 440.64.00-0ubuntu1 is to be installed
                      Depends: libnvidia-compute-440 (= 440.59-0ubuntu0.18.04.1) but 440.64.00-0ubuntu1 is to be installed
                      Depends: libnvidia-decode-440 (= 440.59-0ubuntu0.18.04.1) but it is not going to be installed
                      Depends: libnvidia-encode-440 (= 440.59-0ubuntu0.18.04.1) but it is not going to be installed
                      Depends: libnvidia-fbc1-440 (= 440.59-0ubuntu0.18.04.1) but 440.82-0ubuntu0~0.18.04.2 is to be installed
                      Recommends: nvidia-settings but it is not going to be installed
                      Recommends: nvidia-prime (= 0.8) but it is not going to be installed
                      Recommends: libnvidia-compute-440:i386 (= 440.59-0ubuntu0.18.04.1) but it is not installable
                      Recommends: libnvidia-decode-440:i386 (= 440.59-0ubuntu0.18.04.1) but it is not installable
                      Recommends: libnvidia-encode-440:i386 (= 440.59-0ubuntu0.18.04.1) but it is not installable
                      Recommends: libnvidia-ifr1-440:i386 (= 440.59-0ubuntu0.18.04.1) but it is not installable
                      Recommends: libnvidia-fbc1-440:i386 (= 440.59-0ubuntu0.18.04.1) but it is not installable
                      Recommends: libnvidia-gl-440:i386 (= 440.59-0ubuntu0.18.04.1) but it is not installable
Info on my OS (output of lsb_release -a):
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.4 LTS
Release:    18.04
Codename:   bionic
Any help? :)
gab
  • 141
