in a nutshell, things seem to be good from the ofono-phonesim perspective in terms of modems, but I still can't get HFP audio telephony to work for calls (meanwhile A2DP works flawlessly for music playback).
I'm on Ubuntu 20.04 Focal Fossa, arm64.
This is a follow up to my earlier question. It may seem to be a duplicate of this question but, my use case is the opposite, as I'm trying to use the Linux machine's USB peripherals ($15 mic and $15 speaker bar) as the Headset Unit role, and a mobile device as the Audio Gateway.
Additionally, I've attempted the top answer, specifically everything up to this point:
ofono-phonesim -p 12345 /usr/share/phonesim/default.xml
with
dbus-send --print-reply --system --dest=org.ofono /phonesim org.ofono.Modem.SetProperty string:"Powered" variant:boolean:"true"
and
/ofono/test$ ./enable-modem
and it looks like I'm good from a modem perpective, however I still get no audio for telephony, and I get "Failed to change profile to headset_audio_gateway" in blueman when i try to set the Smart Phone to Headset Audio Gateway (HSP/HFP) manually.
Here's the output for ~/ofono/test/list-modems:
user@machine:~/dir$ ofono-phonesim -p 12345 /usr/share/phonesim/default.xml&
[2] 6834
user@machine:~/dir$ dbus-send --print-reply --system --dest=org.ofono /phonesim org.ofono.Modem.SetProperty string:"Powered" variant:boolean:"true"
method return time=1645567249.694253 sender=:1.163 -> destination=:1.166 serial=33 reply_serial=2
user@machine:~/dir/ofono/test$ ./enable-modem /hfp/org/bluez/hci0/dev_E0_D0_83_93_CC_5A
Connecting modem /hfp/org/bluez/hci0/dev_E0_D0_83_93_CC_5A...
user@machine:~/dir/ofono/test$ test/list-modems
bash: test/list-modems: No such file or directory
user@machine:~/dir/ofono/test$ ./list-modems
[ /hfp/org/bluez/hci0/dev_E0_D0_83_93_CC_5A ]
Online = 1
Powered = 1
Lockdown = 0
Emergency = 0
Serial = E0:D0:83:93:CC:5A
Interfaces = org.ofono.VoiceCallManager org.ofono.CallVolume org.ofono.Handsfree org.ofono.NetworkRegistration
Features = net
Name = enwave64's Note10
Type = hfp
[ org.ofono.VoiceCallManager ]
EmergencyNumbers = 118 110 08 911 000 112 999 119
[ org.ofono.CallVolume ]
SpeakerVolume = 50
MicrophoneVolume = 50
Muted = 0
[ org.ofono.Handsfree ]
InbandRinging = 1
EchoCancelingNoiseReduction = 1
DistractedDrivingReduction = 0
VoiceRecognition = 0
Features = three-way-calling echo-canceling-and-noise-reduction voice-recognition release-all-held release-specified-active-call private-chat create-multiparty hf-indicators
BatteryChargeLevel = 2
[ org.ofono.NetworkRegistration ]
Status = registered
Mode = auto-only
Name =
Strength = 40
[ /phonesim ]
Online = 0
Powered = 1
Lockdown = 0
Emergency = 0
Manufacturer = MeeGo
Model = Synthetic Device
Revision = REV1
Serial = 1234567890
Interfaces = org.ofono.SmartMessaging org.ofono.PushNotification org.ofono.MessageManager org.ofono.Phonebook org.ofono.TextTelephony org.ofono.RadioSettings org.ofono.CallForwarding org.ofono.SimToolkit org.ofono.SimAuthentication org.ofono.AllowedAccessPoints org.ofono.VoiceCallManager org.ofono.SimManager
Features = sms tty rat stk sim
Type = hardware
[ org.ofono.SmartMessaging ]
[ org.ofono.PushNotification ]
[ org.ofono.MessageManager ]
ServiceCenterAddress = +15551234567
UseDeliveryReports = 0
Bearer = cs-preferred
Alphabet = default
[ org.ofono.Phonebook ]
[ org.ofono.TextTelephony ]
Enabled = 1
[ org.ofono.RadioSettings ]
TechnologyPreference = any
AvailableTechnologies = gsm umts lte
[ org.ofono.CallForwarding ]
VoiceUnconditional =
VoiceBusy =
VoiceNoReply =
VoiceNoReplyTimeout = 20
VoiceNotReachable =
ForwardingFlagOnSim = 0
[ org.ofono.SimToolkit ]
IdleModeText =
IdleModeIcon =
MainMenuTitle =
MainMenuIcon =
MainMenu =
[ org.ofono.SimAuthentication ]
NetworkAccessIdentity = 12345678@phonesim.org
[ org.ofono.AllowedAccessPoints ]
EmergencyNumbers = 911 1020 112
[ org.ofono.SimManager ]
Present = 1
CardIdentifier = 8949222074451242066
SubscriberIdentity = 246813579
ImsPrivateIdentity = 12345678@phonesim.org
FixedDialing = 0
BarredDialing = 0
MobileCountryCode = 246
MobileNetworkCode = 81
SubscriberNumbers = 358501234567
LockedPins =
ServiceNumbers = [112] = '112' [Emergency] = '999' [Police] = '997' [Firemen] = '998' [Sea emergency] = '+48601100100' [Mountain emer.] = '+48601100300' [.HELP DESK] = '2601' [.RECHARGE] = '5555' [.Voicemail] = '+48601222222' [.Voice access] = '+48601104444'
PreferredLanguages = de en it fr es nl
PinRequired = none
Retries = [pin = 3]
CardSlotCount = 1
ActiveCardSlot = 1
bluetoothd only seems to give useful info related to A2DP.
Any ideas? Has anyone gotten this to work with the phone as the Audio Gateway?
edit:
cat /var/log/syslog* | grep -i pulse shows [datetime][machine] pulseaudio[839]: Refused to switch profile to headset_audio_gateway: Not connected after attempting to switch to HFP manually in blueman.
Update Feb 24 2022:
So I realized that I had headset=native set in /etc/pulse/default.pa, from some earlier testing where I was trying to ensure HSP instead of HFP. So now that i've set headset=ofono I'm no longer getting an error message "Failed to change profile to headset_audio_gateway" when I switch to HFP.
output from $ pacmd list-cards:
index: 4
driver: <module-bluez5-device.c>
owner module: 28
properties:
device.description = "enwave64's Note10"
device.string = "E0:D0:83:93:CC:5A"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "phone"
bluez.path = "/org/bluez/hci0/dev_E0_D0_83_93_CC_5A"
bluez.class = "0x5a020c"
bluez.alias = "enwave64's Note10"
device.icon_name = "audio-card-bluetooth"
profiles:
headset_head_unit: Headset Head Unit (HSP/HFP) (priority 30, available: no)
a2dp_source: High Fidelity Capture (A2DP Source) (priority 20, available: unknown)
headset_audio_gateway: Headset Audio Gateway (HSP/HFP) (priority 10, available: yes)
off: Off (priority 0, available: yes)
active profile: <headset_audio_gateway>
sinks:
bluez_sink.E0_D0_83_93_CC_5A.headset_audio_gateway/#7: enwave64's Note10
sources:
bluez_sink.E0_D0_83_93_CC_5A.headset_audio_gateway.monitor/#17: Monitor of enwave64's Note10
bluez_source.E0_D0_83_93_CC_5A.headset_audio_gateway/#18: enwave64's Note10
ports:
phone-output: Phone (priority 0, latency offset 0 usec, available: yes)
properties:
phone-input: Phone (priority 0, latency offset 0 usec, available: yes)
properties:
So at least I see headset_audio_gateway: Headset Audio Gateway (HSP/HFP) (priority 10, available: yes) now. Now the issue is it seems like I can switch to HSP/HFP okay, but I'm still getting silence. This was the same result I would get with HSP before installing ofono & ofono-phonesim.
last piece of new info from cat /var/log/syslog* | grep -i pulse: pulseaudio[882]: Deferred setup faild on fd -1: Transport endpoint is not connected. Not exactly sure what this means or if it's relevant but looks to be a new error.
