Background: I'm trying to build and install ofono-phonesim from source, on Ubuntu 20.04 aarch64, so I can get HFP to work with Pulseaudio 13.99. I'm doing this because of the following: This answer says to go here, however the package there is still unavailable to me, I presume because it's amd64.
However when run ./configure on the repo directory I get notified that Qt is not found, even though I've installed Qt5:
checking for QT... no
configure: error: Qt is required
The line in configure.ac: PKG_CHECK_MODULES(QT, Qt5Core Qt5Gui Qt5Xml Qt5Network Qt5Qml Qt5DBus [Qt5Widgets >= 5.10], dummy=yes, AC_MSG_ERROR(Qt is required))
full console output:
user@machine:~/directory/phonesim$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
however, I've already installed Qt5:
user@machine:~/directory/phonesim$ dpkg -l | grep libqt5
ii  libqt5concurrent5:arm64                       5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 concurrent module
ii  libqt5core5a:arm64                            5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 core module
ii  libqt5dbus5:arm64                             5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 D-Bus module
ii  libqt5designer5:arm64                         5.12.8-0ubuntu1                        arm64        Qt 5 designer module
ii  libqt5gui5:arm64                              5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 GUI module
ii  libqt5help5:arm64                             5.12.8-0ubuntu1                        arm64        Qt 5 help module
ii  libqt5network5:arm64                          5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 network module
ii  libqt5opengl5:arm64                           5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 OpenGL module
ii  libqt5opengl5-dev:arm64                       5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 OpenGL library development files
ii  libqt5printsupport5:arm64                     5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 print support module
ii  libqt5qml5:arm64                              5.12.8-0ubuntu1                        arm64        Qt 5 QML module
ii  libqt5quick5:arm64                            5.12.8-0ubuntu1                        arm64        Qt 5 Quick library
ii  libqt5quickcontrols2-5:arm64                  5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 Quick Controls 2 library
ii  libqt5quicktemplates2-5:arm64                 5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 Quick Templates 2 library
ii  libqt5sql5:arm64                              5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 SQL module
ii  libqt5svg5:arm64                              5.12.8-0ubuntu1                        arm64        Qt 5 SVG module
ii  libqt5test5:arm64                             5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 test module
ii  libqt5texttospeech5:arm64                     5.12.8-0ubuntu1                        arm64        Speech library for Qt - libraries
ii  libqt5waylandclient5:arm64                    5.12.8-0ubuntu1                        arm64        QtWayland client library
ii  libqt5waylandcompositor5:arm64                5.12.8-0ubuntu1                        arm64        QtWayland compositor library
ii  libqt5widgets5:arm64                          5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 widgets module
ii  libqt5x11extras5:arm64                        5.12.8-0ubuntu1                        arm64        Qt 5 X11 extras
ii  libqt5xdg3:arm64                              3.4.0-1build2                          arm64        Implementation of the XDG Specifications for Qt (shared lib)
ii  libqt5xdgiconloader3:arm64                    3.4.0-1build2                          arm64        Implementation of the XDG Iconloader for Qt (shared lib)
ii  libqt5xml5:arm64                              5.12.8+dfsg-0ubuntu1                   arm64        Qt 5 XML module
How can I make Qt5 visible in this context? A little new to Linux and Autotools, so please and thank you.
Reproducible method would be an adaptation of already known answer - you compile the software using deb-src from PPA repository:
sudo add-apt-repository -s ppa:smoser/bluetooth
sudo apt-get update
sudo apt-get build-dep ofono-phonesim # will install all dependencies
cd ~/Downloads apt-get source -b ofono-phonesim sudo apt-get install ../ofono-phonesim_1.21-16-gadf231a8-0smoser0_arm64.deb
Notes:
  1. you can replace last two commands with yours planned commands such as ./configure, make -j$(nproc) and sudo checkinstall. But I would recommend to use two above last commands as they were written.
  2. I wrote an request for armhf and arm64 builds to PPA owner.
N0rbert
  • 103,263
