23
I want to disable lightdm from autostart. Currenty, I run service lightdm disable from terminal, then run startx.
update-rc.d doesnt help
Samat
  • 595
5 Answers5
24
As described here, one can now disable lightdm like this:
systemctl disable lightdm.service
19
lightdm is started by Upstart, not SysV Init. So update-rc.d doesn't work.
Use
 echo  "manual" | sudo tee -a /etc/init/lightdm.override
orrymr
  • 195
If you want to disable lightdm to enable gdm or kdm or any other display manager, enter the following command in the terminal:
sudo dpkg-reconfigure lightdm
Then enter on ok and then select from the list your desired display manager.
The same answer with screenshots is given here: Reset to Default Unity Login
Nirmik
  • 7,938
This is handled by display-manager... Disable on systemd and you're done.
# systemctl disable display-manager
Removed symlink /etc/systemd/system/display-manager.service.
Trunet
  • 31
I just remove the execution bit on the lightdm binary.
chmod -x /usr/sbin/lightdm
Then to re-enable it:
chmod +x /usr/sbin/lightdm
John
