Edit: Noted later in post but I've tested in 20.04 with similar results. If post needs to be removed then go for it.
I have a few hardware issues that I believe might be related? I recently moved a drive with Ubuntu 21.04 (GNOME 3.38.5 and X11) from an HP 8300 to an Intel NUC 11 NUC11PAHi7. .
  1. I have a dummy HDMI that when plugged in directly to HDMI port nothing happens (No display just a black screen). I’ve looked at the log file and nothing is registered when I plug and unplug the dummy.
    • When I plug in the same dummy HDMI via HDMI to USB-C adapter the adapter shows up in the logs but not the HDMI
    • When I plug in the dummy HDMI via a USB-C hub (7 in 1) everything works fine.
  2. If I disconnect HDMI from my machine while booted the system will lock up within 12 hours of the disconnect (It honestly seems quicker maybe 2-6 hours but the first time I noticed this was overnight after I’d gone to bed so I’ll assume it ran for a while)
    • I can start with HDMI connected or connect my monitor after boot with no issues, but if I disconnect after either of these events my computer becomes unresponsive
      1. The system runs headless so I usually SSH in or use VNC (hence the dummy HDMI). However, after I’ve disconnected HDMI (the dummy or an actual HDMI connected to a monitor) my system loses connection to the internet sometime in the 12 hour window (no access to HomeAssistant, SSH or VNC).
      2. At this point I can only assume the entire system locks up. I haven't been able to diagnose this any further because re-connecting an HDMI at this point in the process yields a “No Signal” from my monitor. The only methods I know to get everything back up is a hard restart or Ctrl+Print Screen+REISUB
    • When logged in via VNC I’ve noticed that after disconnecting the HDMI the screen doesn’t go back to a black screen. A couple of the icons move and the GUI just hangs.
  3. If, while my system is booted, I connect a new device (USB and HDMI tested so far) my keyboard(Bluetooth dongle connected via USB-C hub) becomes laggy (every other input received or ~2-6 keystrokes delayed) at best and in most cases completely unresponsive.
    • The keyboard suffers the same issue when connected directly in USB ports from boot no matter what.
    • The mouse (also Bluetooth) is a bit jumpy when connected directly via USB as well.
The results seemed the same when booting from an Ubuntu 20.04LTS install USB under the “Try Ubuntu” Option although I admittedly didn’t test as extensively. It haven't been able to reproduce the display problem on another OS as all the other computers I have access to (Windows and Mac) can run headless without needing a display attached. Running windows from an SSD in the same NUC had no I/O issues. I haven’t tried new drivers yet as everything works via USB-C and I’ll try wired keyboard/mouse tomorrow when I can borrow some. The system lock up thing has thrown me. I can post logs or screenshots but I’m not sure where to start/what would be helpful.
Thanks in advance
