Ubuntu 22.04 fresh install. Everything initially appeared to be working OK. I was able to use remote desktop using TightVNC but then I noticed VNC wouldn't reconnect if the screen blanked. Worse, if I disconnected the monitor for any length of time and then reconnected it, there is no display on the monitor. I can still log in via SSH but I would like to be able to use VNC without having a monitor permanently connected.
Rob190
Seems this is an old issue e.g.:
How to use Ubuntu 18.04 on VNC without display attached?
Input/output device issues in Ubuntu 20.04
There are partial workarounds involving the creation of a dummy monitor but if you want to swap between using a physical monitor and VNC, you will likely run into the problem where the monitor just displays a blank screen with a cursor top left.
The only reliable solution appears to be to use a dummy HDMI e.g. https://thepihut.com/products/hdmi-dummy-plug.
A hardware workaround for a software bug. Got to be a first.
Rob190
