The actually weird thing is that my usb-keyboard shows as wakeup enabled.
grep . /sys/bus/usb/devices/*/product
outputs
/sys/bus/usb/devices/2-2/product:Mechanical Keyboard
/sys/bus/usb/devices/2-3/product:USB OPTICAL MOUSE
/sys/bus/usb/devices/usb1/product:EHCI Host Controller
/sys/bus/usb/devices/usb2/product:xHCI Host Controller
/sys/bus/usb/devices/usb3/product:xHCI Host Controller
and
grep . /sys/bus/usb/devices/*/power/wakeup
outputs
/sys/bus/usb/devices/1-1/power/wakeup:disabled
/sys/bus/usb/devices/2-2/power/wakeup:enabled
/sys/bus/usb/devices/2-3/power/wakeup:enabled
/sys/bus/usb/devices/2-5/power/wakeup:disabled
/sys/bus/usb/devices/usb1/power/wakeup:disabled
/sys/bus/usb/devices/usb2/power/wakeup:enabled
/sys/bus/usb/devices/usb3/power/wakeup:disabled
Now, I admit, my laptop setup is a little weird in that I have disconnected both the laptop screen, built-in keyboard and touchpad. I only reconnect them prior to travelling and then, only reluctantly. But that shouldn't matter because,
a) it has presented no other problems
b) when I reconnect them, waking from the usb-keyboard still doesn't work. Waking from the built-in keyboard works just fine.
I run Ubuntu 20.04.3 LTS and always avoid major under the hood tinkering if I can, if that helps. The laptop is an Acer Travelmate p256-mg.
Vikare
  • 33
This is something that I have seen in the past on an HP ProBook and a Dell Precision notebook. The issue came down to the machine not quite going to sleep and, because it wasn't sleeping, it couldn't be woken with a keypress from an external keyboard. Like your machine, though, the built-in keyboard would allow the machine to resume. In the end, the solution was to modify Grub a bit.
Here is how you can do it, too:
  1. Open a Terminal (if it's not already open)
  2. Open /etc/default/grub for editing with sudo:
    sudo {editor of choice} /etc/default/grub
    Note: Be sure to replace {editor of choice} with your editor of choice.
    Find the line that starts GRUB_CMDLINE_LINUX_DEFAULT. You will be adding settings to this line. Be sure to leave any existing values untouched.
  3. If you have an Nvidia video adapter, add rcutree.rcu_idle_gp_delay=1 to the end of the GRUB_CMDLINE_LINUX_DEFAULT value. For example:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash rcutree.rcu_idle_gp_delay=1"
    Note: There are instances where an Nvidia device can prevent a machine from entering into sleep/standby, and this is an effective solution.
  4. Add mem_sleep_default=deep to GRUB_CMDLINE_LINUX_DEFAULT, ensuring memory is completely recorded to the storage device when entering sleep. You may now have something like this
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash rcutree.rcu_idle_gp_delay=1 mem_sleep_default=deep"
    Note: This has generally been the setting I've needed to configure in order to resolve the external keyboard issue.
  5. Save the file
  6. Update Grub:
    sudo update-grub
  7. Reboot.
This should ensure the notebook enters a proper sleep state, allowing it to now properly respond to wake actions.
matigo
  • 24,752
  • 50
  • 79
