I am running Ubuntu (20.04 LTS) on my laptop (Asus ZenBook 13 OLED UX325) and I enjoy it for the most part. However, there I have one issue that is driving my crazy. If the laptop is left idle for a period of time, the screen turns black and it is impossible to undo it after it enters some sort of hibernation or sleep (or suspend?) mode. In other words, it enters some sort of sleep mode, and will not wake up when any buttons are pushed. The only solution forcibly turn off the laptop using the power button. This only occurs if it is left idle for a sufficient amount of time -- if I am quick enough after the screen turns black, I am able to press any key and log in normally.
Do anyone have an idea how to fix this for my specific laptop? I tried adding nouveau.modeset=0 to GRUB_CMDLINE_LINUX="" from this answer without any luck.
Edit (added /var/log/syslog as requested by @matigo in the comments):
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA avahi-daemon[743]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA NetworkManager[752]: <info>  [1641480035.2654] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA wpa_supplicant[787]: wlp1s0: CTRL-EVENT-SCAN-FAILED ret=-100
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA nm-dispatcher[4283]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA wpa_supplicant[787]: nl80211: deinit ifname=p2p-dev-wlp1s0 disabled_11b_rates=0
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA systemd[1]: Reached target Sleep.
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA systemd[1]: Starting Record successful boot for GRUB...
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA systemd[1]: Starting Suspend...
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA kernel: [ 2959.035172] PM: suspend entry (s2idle)
Jan  6 15:40:35 abc-ZenBook-UX325UA-UM325UA systemd-sleep[4290]: Suspending system...
^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@Jan  6 16:01:53 abc-ZenBook-UX325UA-UM325UA systemd-modules-load[382]: Inserted module 'lp'
Jan  6 16:01:53 abc-ZenBook-UX325UA-UM325UA systemd-modules-load[382]: Inserted module 'ppdev'
Jan  6 16:01:53 abc-ZenBook-UX325UA-UM325UA systemd-modules-load[382]: Inserted module 'parport_pc'
Jan  6 16:01:53 abc-ZenBook-UX325UA-UM325UA systemd-modules-load[382]: Inserted module 'msr'
Jan  6 16:01:53 abc-ZenBook-UX325UA-UM325UA systemd-sysctl[399]: Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
NB! I pushed many buttons for it to be easier to locate in the vast /var/log/syslog file.
