I am new to Ubuntu. I have installed Ubuntu 12.04 and am stuck trying to set up the correct resolution for my LCD display.
The native resolution for the LCD is 1920x1080
here is the output from xrandr:
$ xrandr
Screen 0: minimum 320 x 200, current 1280 x 720, maximum 4096 x 4096
LVDS1 connected 1280x720+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1280x720 60.0*+
800x600 60.3 56.2
640x480 59.9
VGA1 disconnected (normal left inverted right x axis y axis)
Then I create new modeline:
$ cvt 1920 1080 60
1920x1080 59.96 Hz (CVT 2.07M9) hsync: 67.16 kHz; pclk: 173.00 MHz
Modeline "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
So far so good. Then I create new mode using xrandr:
$ xrandr --newmode "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
But for some reason that new mode was created for VGA (VGA1) output instead of LCD output (LVDS1):
$ xrandr
1280x720 60.0*+
800x600 60.3 56.2
640x480 59.9
1920x1080_60.00 (0xbc) 173.0MHz <---------- ????!!!!!!
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.2KHz
v: height 1080 start 1083 end 1088 total 1120 clock 60.0Hz
So, if I try to add mode to LVDS1, I get an error:
$ xrandr --addmode LVDS1 "1920x1080_60.00"
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 149 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 25
Current serial number in output stream: 26
Adding that new mode to VGA1 works fine, but I don't use that VGA1 output.
